Trying to get a Session variable to equal a Recordset Value
Thread begun 2/01/2010 9:20 pm by ijk76319396 | Last modified 2/05/2010 2:40 pm by Jason Byrnes | 8912 views | 8 replies |
ijk76319396
I am trying to get a session variable to equal a recordset value, I am writing the variable as
<?php $_SESSION['COMMID']=$_rsPAGES['page_1']; ?>
However the value for it comes up empty when I try to display it.
The query rsPAGES is filtered by a GET value that equals a SEPARATE session variable that I have directly above the first one I typed. It looks like...
<?php $_SESSION['PAGEID']=$_GET['ID']; ?>
Is it possible to do what I am trying to do here. The rsPAGES values work fine when displayed on other parts of the page but when I try to incorporate them into the session variable I get nothing.
PHP can be tricky about "seeing" the session.
any time you are trying to set or display a session, you should include the following code first to force php to look for the session contents:
if(!session_id()) session_start();
so to set the session use:
then to display it use:
echo
$_SESSION['COMMID'];
Also, make sure that the code you are using to set the session value is after the code to create the recordset.
ijk76319396
I have been working on the solution and found that I needed to add row before the rsPAGEs so its now
$_SESSION['COMMID']=$row_rsPAGES['page_1'];
If you go to web_comicxx.php?ID=6 you can see what I am trying to do. Now that I added that the echo works fine, it is the text directly under the "by Administrator" at the top of the page, however I am not concerned with displaying the text, rather I want to use the COMMID session value to filter the pages by comments in recordset4. So when someone enters a comment in the database the session value is entered into the applicable field, THIS WORKS as far as being entered correctly into the database, now the problem is with the recordset4 which I am trying to filter using the session variable of COMMID so the comment made should only show up on the page it was made on... however it's not working that way, it shows up sometimes on some pages, then not at all, sometimes I have to hit refresh to see anything. Any idea what could be causing this not to work? I am pasting the relevant code.
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$currentPage = $_SERVER["PHP_SELF"];
$editFormAction = $_SERVER['PHP_SELF'];
if (isset($_SERVER['QUERY_STRING'])) {
$editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "form1")) {
$insertSQL = sprintf("INSERT INTO messages (username, subject, message, sender, senderID) VALUES (%s, %s, %s, %s, %s)",
GetSQLValueString($_POST['hiddenField'], "text"),
GetSQLValueString($_POST['subject2'], "text"),
GetSQLValueString($_POST['message2'], "text"),
GetSQLValueString($_POST['SENDER'], "text"),
GetSQLValueString($_POST['SENDERID'], "text"));
mysql_select_db($database_con2com, $con2com);
$Result1 = mysql_query($insertSQL, $con2com) or die(mysql_error());
$insertGoTo = "../messagesent.php";
$insertGoTo .= (strpos($insertGoTo, '?')) ? "&" : "?";
$insertGoTo .= $_SERVER['QUERY_STRING'];
header(sprintf("Location: %s", $insertGoTo));
ijk76319396
Had to post the remaining php down here because it was too long...
$colname_Recordset1 = "-1";
if (isset($_SESSION['PAGEID'])) {
$colname_Recordset1 = (get_magic_quotes_gpc()) ? $_SESSION['PAGEID'] : addslashes($_SESSION['PAGEID']);
$query_Recordset1 = sprintf("SELECT * FROM members WHERE ID = %s", GetSQLValueString($colname_Recordset1, "int"));
$Recordset1 = mysql_query($query_Recordset1, $con2com) or die(mysql_error());
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
$totalRows_Recordset1 = mysql_num_rows($Recordset1);
$query_Recordset3 = "SELECT ID FROM members ORDER BY ID DESC";
$Recordset3 = mysql_query($query_Recordset3, $con2com) or die(mysql_error());
$row_Recordset3 = mysql_fetch_assoc($Recordset3);
$totalRows_Recordset3 = mysql_num_rows($Recordset3);
$maxRows_Recordset4 = 10;
$pageNum_Recordset4 = 0;
if (isset($_GET['pageNum_Recordset4'])) {
$pageNum_Recordset4 = $_GET['pageNum_Recordset4'];
$startRow_Recordset4 = $pageNum_Recordset4 * $maxRows_Recordset4;
$colname_Recordset4 = "-1";
if (isset($_SESSION['COMMID'])) {
$colname_Recordset4 = (get_magic_quotes_gpc()) ? $_SESSION['COMMID'] : addslashes($_SESSION['COMMID']);
$query_Recordset4 = sprintf("SELECT * FROM comments WHERE pageID = %s ORDER BY ID DESC", GetSQLValueString($colname_Recordset4, "text"));
$query_limit_Recordset4 = sprintf("%s LIMIT %d, %d", $query_Recordset4, $startRow_Recordset4, $maxRows_Recordset4);
$Recordset4 = mysql_query($query_limit_Recordset4, $con2com) or die(mysql_error());
$row_Recordset4 = mysql_fetch_assoc($Recordset4);
if (isset($_GET['totalRows_Recordset4'])) {
$totalRows_Recordset4 = $_GET['totalRows_Recordset4'];
} else {
$all_Recordset4 = mysql_query($query_Recordset4);
$totalRows_Recordset4 = mysql_num_rows($all_Recordset4);
$totalPages_Recordset4 = ceil($totalRows_Recordset4/$maxRows_Recordset4)-1;
$query_rsVALIDATOR = "SELECT ID FROM comments ORDER BY ID DESC";
$rsVALIDATOR = mysql_query($query_rsVALIDATOR, $con2com) or die(mysql_error());
$row_rsVALIDATOR = mysql_fetch_assoc($rsVALIDATOR);
$totalRows_rsVALIDATOR = mysql_num_rows($rsVALIDATOR);
$maxRows_rsPAGES = 1;
$pageNum_rsPAGES = 0;
if (isset($_GET['pageNum_rsPAGES'])) {
$pageNum_rsPAGES = $_GET['pageNum_rsPAGES'];
$startRow_rsPAGES = $pageNum_rsPAGES * $maxRows_rsPAGES;
$colname_rsPAGES = "-1";
$colname_rsPAGES = (get_magic_quotes_gpc()) ? $_SESSION['PAGEID'] : addslashes($_SESSION['PAGEID']);
$query_rsPAGES = sprintf("SELECT * FROM uploads WHERE ID = %s ORDER BY message_id DESC", GetSQLValueString($colname_rsPAGES, "text"));
$query_limit_rsPAGES = sprintf("%s LIMIT %d, %d", $query_rsPAGES, $startRow_rsPAGES, $maxRows_rsPAGES);
$rsPAGES = mysql_query($query_limit_rsPAGES, $con2com) or die(mysql_error());
$row_rsPAGES = mysql_fetch_assoc($rsPAGES);
if (isset($_GET['totalRows_rsPAGES'])) {
$totalRows_rsPAGES = $_GET['totalRows_rsPAGES'];
} else {
$all_rsPAGES = mysql_query($query_rsPAGES);
$totalRows_rsPAGES = mysql_num_rows($all_rsPAGES);
$totalPages_rsPAGES = ceil($totalRows_rsPAGES/$maxRows_rsPAGES)-1;
$colname_rsRATINGS = "-1";
$colname_rsRATINGS = (get_magic_quotes_gpc()) ? $_SESSION['PAGEID'] : addslashes($_SESSION['PAGEID']);
$query_rsRATINGS = sprintf("SELECT * FROM rating WHERE ARTISTusername = %s ORDER BY rating DESC", GetSQLValueString($colname_rsRATINGS, "text"));
$rsRATINGS = mysql_query($query_rsRATINGS, $con2com) or die(mysql_error());
$row_rsRATINGS = mysql_fetch_assoc($rsRATINGS);
$totalRows_rsRATINGS = mysql_num_rows($rsRATINGS);
$colname_rsAVGRATING = "-1";
$colname_rsAVGRATING = (get_magic_quotes_gpc()) ? $_SESSION['PAGEID'] : addslashes($_SESSION['PAGEID']);
$query_rsAVGRATING = sprintf("SELECT FORMAT(AVG(rating), 2) AS averageRating FROM rating WHERE ARTISTusername = %s", GetSQLValueString($colname_rsAVGRATING, "int"));
$rsAVGRATING = mysql_query($query_rsAVGRATING, $con2com) or die(mysql_error());
$row_rsAVGRATING = mysql_fetch_assoc($rsAVGRATING);
$totalRows_rsAVGRATING = mysql_num_rows($rsAVGRATING);
$query_rsADMIN = "SELECT * FROM adminstuff";
$rsADMIN = mysql_query($query_rsADMIN, $con2com) or die(mysql_error());
$row_rsADMIN = mysql_fetch_assoc($rsADMIN);
$totalRows_rsADMIN = mysql_num_rows($rsADMIN);
$colname_rsSCORE = "-1";
$colname_rsSCORE = (get_magic_quotes_gpc()) ? $_SESSION['PAGEID'] : addslashes($_SESSION['PAGEID']);
$query_rsSCORE = sprintf("SELECT SUM(points) AS sumScore FROM combinedscore WHERE userID = %s", GetSQLValueString($colname_rsSCORE, "text"));
$rsSCORE = mysql_query($query_rsSCORE, $con2com) or die(mysql_error());
$row_rsSCORE = mysql_fetch_assoc($rsSCORE);
$totalRows_rsSCORE = mysql_num_rows($rsSCORE);
$colname_rsSUB = "-1";
$colname_rsSUB = (get_magic_quotes_gpc()) ? $_SESSION['PAGEID'] : addslashes($_SESSION['PAGEID']);
$query_rsSUB = sprintf("SELECT * FROM subscribe WHERE SUBEEID = %s", GetSQLValueString($colname_rsSUB, "text"));
$rsSUB = mysql_query($query_rsSUB, $con2com) or die(mysql_error());
$row_rsSUB = mysql_fetch_assoc($rsSUB);
$totalRows_rsSUB = mysql_num_rows($rsSUB);
$queryString_Recordset4 = "";
if (!empty($_SERVER['QUERY_STRING'])) {
$params = explode("&", $_SERVER['QUERY_STRING']);
$newParams = array();
foreach ($params as $param) {
if (stristr($param, "pageNum_Recordset4") == false &&
stristr($param, "totalRows_Recordset4") == false) {
array_push($newParams, $param);
if (count($newParams) != 0) {
$queryString_Recordset4 = "&" . htmlentities(implode("&", $newParams));
$queryString_Recordset4 = sprintf("&totalRows_Recordset4=%d%s", $totalRows_Recordset4, $queryString_Recordset4);
$queryString_rsPAGES = "";
if (stristr($param, "pageNum_rsPAGES") == false &&
stristr($param, "totalRows_rsPAGES") == false) {
$queryString_rsPAGES = "&" . htmlentities(implode("&", $newParams));
$queryString_rsPAGES = sprintf("&totalRows_rsPAGES=%d%s", $totalRows_rsPAGES, $queryString_rsPAGES);
?><?php
You are creating the COMMID session variable after the recordset4 code.
PHP code is executed from top to bottom, for the recordset4 recordset to be able to filter on the COMMID session variable, the COMMID session variable must be created before the recordset4 recordset.
ijk76319396
Got it to work, now the only problem is that when I go to a different page the comments show from the previous page I was on, I can get the correct comments but I have to hit refresh, how can I avoid this, do I need some sort of one time autorefresh? What's the best way to do this?
Most likely it is a code order problem again, but I cant say without seeing the code.
Add the page to a zip archive and attach the zip file so I can see the code.
ijk76319396
Attached it.
Yeah, so line 256 is where you set the COMMID session variable:
your using the rsPAGES recordset which is created at line 153 - 175
you are using it to filter the Recordset4 recordset at lines 121 - 136, since it has not been set yet, it is using the value from the previous page.
you need to re order the code so that
1) the rsPAGES recordset is created
2) the COMMID session variable is set
3) the Recordset4 recordset is created.
