Security Assist Wizard problems
Thread begun 2/01/2010 3:04 pm by mr hankey | Last modified 2/23/2010 4:46 pm by Eric Mittman | 2585 views | 3 replies |
mr hankey
When going through the wizard i have problems.
When i select a page for "redirect if login succeeds" to a page that data assist create or my index page it says "the file that you have chosen is not based on the selected template, it is not template based...."
it is as i created the data assist insert pages etc with this template.
i also got another error when using this the other day saying that it could not make changes when it was building the pages as it is locked for editing however the file is not open at all.
can someone assist?
many thanks
I was trying to get the error you are seeing occur without success. I ran DataAssist and based the pages off a template. I then ran Security Assist and I tried specifying one of the DataAssist pages as the redirect page. It said the page was based off a template and I needed to select a template from the wizard to do this.
I then selected the template from the wizard and made this selection again and it took without issue. I'm wondering if this is an issue with the template file you are using. Please post back with this file so that I can do some more testing on it to see if I can ge the same result.
Have you had the other error occur more than once? Did this happen for you when you were getting the first error? Please post back with some specific steps that you are taking when you get this error so that we can check on this also.
mr hankey
hi eric sorry for delay, it looks like there was an issue with that template for some reason, i delete it and recreated without any issues, although i do tend to get a warning after using an extension in the editable content region saying somthing like"there was changes outside the editable region and it is locked........."
not sure if that is for concern as once i save it and upload it works as expected.
thanks again
As long as the page is working as expected the error message should be no concern. This is a common error to see when you are working on templates and it does not necessarily mean what the message says. There is a bit of info out there on this that you could find by Googling it. I get it from time to time but have not had it effect me negatively.
