Page title element & description meta tag
Thread begun 2/01/2010 10:00 am by gw311682 | Last modified 2/01/2010 11:42 am by Jimmy Wu | 1247 views | 1 replies |
gw311682
Hello,
I want to add a different page title (using the title element) to each of my store's pages rather than using the 'static' title in the WA_Globals.php file. Similarly, I want to use a different description meta tag for each page as well.
Is this as simple as deleting the <title>Home - <?php echo($WAGLOBAL_Site_Name); ?></title> line and substituting the <title> </title> & <meta name=“description” content=“xxx” /> within the head section?
If you can advise me on this, I’ll be very grateful. Thank you for your time and trouble,
Geoff
Jimmy Wu
That sounds like it should do the trick. The title is just set using the globals file by that call, so if you change the tags, you should be able to customize it the way you want.
