Preset Manager Hangs up when I select Dreamweaver Template
Thread begun 2/01/2010 8:37 am by info319841 | Last modified 2/02/2010 6:03 pm by Eric Mittman | 2403 views | 3 replies |
info319841
When trying to create a preset using a Dreamweaver template, I select the "Use Dreamweaver Template" radio button and when I click "Next" it just hangs. I am using Dreamweaver CS3, CSS Sculptor 3, pc. No other dialog boxes seem to have this problem - just this one.
I'm not following with the interface that you are seeing, is this in the SiteAssist Pro create new layout interface? Please be as specific as you can so that we can look into this with you.
info319841
Sorry. I am using the Preset Manager. Upon further research, it appears to belong to Site Assist Professional. Yes, it's "Create New Layout" using Dreamweaver templates. I did some more hunting around and found a reference to a file in the task manager that seems to be the culpret- it starts out like html.... - anyway, if I kill it 2 or 3 times, I am able to get the interface to move through the wizard steps. But that's pretty cumbersome. Any suggestions would be greatly appreciated and thank you.
Do you know the full name of the process you had to kill? Was it the preview? If so you can disable the preview through Edit > WebAssist Preferences by choosing preview, and disable. Do you have a link for the thread you found this in?
