default setting if recordset is empty?
Thread begun 2/01/2010 7:56 am by sam398359 | Last modified 2/02/2010 12:54 pm by Jason Byrnes | 2847 views | 3 replies |
sam398359
I have a map that gets its "markers" based on the users selection in a dropdown. This all works fine with some basic recordsets.
However, when the page is first loaded and there is no user selection, no map shows at all. But when i view source i can see it has loaded a single blank address from the empty recordset
How do i set the map to a default wide view over the country if the recordset is empty?
I am aware I can set a default "address" with another recordset on the first load, but I do not want an address to show as that is too specific, I want to show the wider area first with no markers on first load.
Any ideas?
can you send a copy of your google_javascript folder so I can take a look at the code. there should not be a blank entry if the recordset is empty, it should default to a map of palo alto.
also, cold you priovide a li nik so I can see the problem in a browser.
sam398359
The files are attached, not hooked up to a live site yet, all data is local. I have included the outputted html page as well.
I see whats going wrong, an error is occurring if the recordset is empty. In the wagmp_map_2.php file, change line 145 - 262 to:
<?php if($totalRows_getUserCities > 0) { ?>
<?php $getUserCities_id
= 0; ?>
do { ?>
    var address_0_<?php echo $getUserCities_id; ?> = {
      street: '<?php echo str_replace("'", "\'", "".$row_getUserCities['store_address']  .""); ?>',
      city: '<?php echo str_replace("'", "\'", "".$row_getUserCities['store_city']  .""); ?>',
      state: '',
      zip: '<?php echo str_replace("'", "\'", "".$row_getUserCities['store_zip']  .""); ?>',
      country: 'Denmark',
      infowindow: 'custom',
      infowindowtext: '<span style="font: 12px Verdana, Arial, Helvetica, sans-serif; color: black;"><strong><?php echo str_replace("'", "\'", "".$row_getUserCities['store_name']  ."</strong><br />".$row_getUserCities['store_address']  ."<br />".$row_getUserCities['store_city']  ."  ".$row_getUserCities['store_zip']  ." Denmark"); ?></span>',
      full: '<?php echo str_replace("'", "\'", "".$row_getUserCities['store_address']  .""); ?>, <?php echo str_replace("'", "\'", "".$row_getUserCities['store_city']  .""); ?>, <?php echo str_replace("'", "\'", "".$row_getUserCities['store_zip']  .""); ?>, Denmark',
      isdefault: true,
      addressType: 'address',
      loop: 'getUserCities',
      latitude: '',
      longitude: '',
      markerStyle: 'Google Traditional (flat)',
      markerColor: 'Pacifica'
    if (address_0_<?php echo $getUserCities_id; ?>.addressType == "coordinates") {
      var cacheReturn = '';
    } else {
      var cacheReturn = searchCache(address_0_<?php echo $getUserCities_id; ?>.full, address_0_<?php echo $getUserCities_id; ?>.zip);
    if (cacheReturn != "" || (address_0_<?php echo $getUserCities_id; ?>.addressType == "coordinates")) {
      if(address_0_<?php echo $getUserCities_id; ?>.addressType == "coordinates") {
        var latitude = address_0_<?php echo $getUserCities_id; ?>.latitude;
        var longitude = address_0_<?php echo $getUserCities_id; ?>.longitude;
      } else {
        var latitude = cacheReturn.substring(1,cacheReturn.indexOf(",")-1);
        var longitude = cacheReturn.substring(cacheReturn.indexOf(",")+1,(cacheReturn.length)-1);
      var point = new GLatLng(latitude, longitude);
      if (point && !isNaN(latitude)) {
        wagmp_map_2_obj.addressFailed = false;
        var marker_0_<?php echo $getUserCities_id; ?> = new GMarker(point, icon_0);
        GEvent.addListener(marker_0_<?php echo $getUserCities_id; ?>, 'click', function() {
          marker_0_<?php echo $getUserCities_id; ?>.openInfoWindowHtml(address_0_<?php echo $getUserCities_id; ?>.infowindowtext);
        if(!fromAddress.enabled || 'address_0_<?php echo $getUserCities_id; ?>' != 'address_0_0') {
          if('address_0_<?php echo $getUserCities_id; ?>' == 'address_0_0')
          map.setCenter(point, 13);
          map.addOverlay(marker_0_<?php echo $getUserCities_id; ?>);
          wagmp_map_2_obj.markers.push(marker_0_<?php echo $getUserCities_id; ?>);
          wagmp_map_2_obj.addresses.push(address_0_<?php echo $getUserCities_id; ?>);
          wagmp_map_2_obj.icons.push(icon_0);
          wagmp_map_2_obj.points.push(point);
        } else {
        if (wagmp_map_2_obj.addressFailed) {
          map.setCenter(new GLatLng(30, -98), 3);
        wagmp_map_2_obj.addressFailed = true;
    } else if (address_0_<?php echo $getUserCities_id; ?>.addressType == "address") {
      geocoder.getLatLng (
      function(point) {
        if(point) {
          this.addressFailed = false;
          addToCache(address_0_<?php echo $getUserCities_id; ?>.full, '', point);
        } else {
          var noZipAddress = address_0_<?php echo $getUserCities_id; ?>.full.replace((address_0_<?php echo $getUserCities_id; ?>.zip+','), '');
          geocoder.getLatLng (noZipAddress,
            function(point) {
              if(point) {
                addToCache(address_0_<?php echo $getUserCities_id; ?>.full, address_0_<?php echo $getUserCities_id; ?>.zip, point);
                if (!fromAddress.enabled || 'address_0_<?php echo $getUserCities_id; ?>' != 'address_0_0') {
              } else {
<?php $getUserCities_id++; ?>
} while ($row_getUserCities = mysql_fetch_assoc($getUserCities)); ?>
<?php mysql_data_seek
($getUserCities, 0); ?>
} else { ?>
<?php } ?>
I am attaching a copy of the file with the code added.
