Formatting form output
Thread begun 2/01/2010 7:45 am by info72555 | Last modified 2/09/2010 7:11 pm by Jimmy Wu | 4412 views | 11 replies |
info72555
The documentation seems a bit limited and I was wondering what settings I need to use to prevent the label name (I think that's what it is) from being shown in the form output.
I have purchased the Contact Form Solution pack and use the template in combination with Form Builder. It works great, except for displaying redundant label information. I have tried to remove it from the code and the output was perfect but the form is then no longer recognized by Form Builder (I cannot edit it).
Link to form: MemberInformation.php
Sample output:
Business Overview group What sets you apart from the competition: test
Business Overview group Your Tag Line, Motto, Philosophy or Mission Statement: test
I would like to hide "Business Overview group "
PS: I was also wondering whether you could PLEASE help me with a glitch I cannot figure out. At the very end of every form submission, "</html" is being added so it would actually display:
</html
I am new to this and have already spent a few hours trying to pinpoint where this is being created. Your help would be GREATLY appreciated!! :o)
Jimmy Wu
The form looks different from your description. Have you already made the changes that were necessary to get it to look the way you want?
info72555
Puzzled...
I am not sure what you mean by 'looks different'. This is the form I am referring to in my initial post and nothing has been changed.
I listed only the last part of the form output to save space. Look at the last 2 fields and you will see they match the form.
info72555
Hello?????
Is anyone going to respond to me??
Thank you
Jimmy Wu
I'm sorry, I misunderstood what you were asking about. The form submits as the form element name, so you would have to change that directly within the form. Form builder names the form elements by adding the fieldset id to the form element id. To get the form elements to submit differently you would just set it as a different id. Make sure all references to that form element are also changed.
info72555
One more question you missed...
Would you please help me with the coding glitch that adds "</html" at the end of the form output? Your help would be greatly appreciated - Thank you.
neilo
If it is appearing like that as text (i.e. not source-code) you could try using Dreamweaver's 'search and replace' 'Entire Current Site' but choose 'Text' from the 'Search:' drop-down list, then click 'Find All'. That may flush it out.
Incidentally, If you just wanted to hide the 'Business Overview' heading from view, but without affecting the validation, or the ability to re-enter the CSFormBuilder edit area, you could just add a couple of inline styles to the html in your page.
The first change hides the 'Business Overview' heading, and the second one closes the gap that it leaves. Find this in your page html:
<li>
<fieldset class="Sharp_Default" id="Business_Overview">
<span class="groupHeader">Business Overview</span>
and change it to:
<li style="margin-top:-45px;">
<span style="display: none;" class="groupHeader">Business Overview</span>
info72555
Thank you!!!
I was wondering if there would be a fix without too much work and you found one! Awesome!!
Thank you, thank you!!!
info72555
Sorry to bug you again - you misunderstood my question...
I jumped the gun and responded to your proposed solution without trying it out.
When I create a form in CSS Form Builder, I need to assign names to the Fieldset Groups. When someone fills out the form, thie fieldset group name is then combined with the name of the field.
Let's say the Fieldset name specified in Form Builder is "Contact Information". The field in the form is called "First Name". I use the template provided in your Contact Solution to format the output. When I receive the form via email, the Fieldset Group name and the name of the Field name are now combined. Instead of showing: " First Name", it displays "Contact Information group First Name". What is the best way to remove the Fieldset Group name from the output? I have gone through the form and removed the Fieldset Group names but that resulted in links being broken and I could no longer edit the form in Form Builder. I hope this time you understand what I am trying to do.
The Search and Replace suggestion for the redundant "</html" that is added at the end of the form output (what is sent to me after someone fills out the form) does not yield any results. It only finds the proper tags so I assume it's a piece of code that creates this oddity. I cannot figure out where and how the "</html" is created and why it is being displayed.
Any help would be GREATLY appreciated. Sorry for my inability to explain my challenges properly the first time.
Jimmy Wu
Can you post up a copy of the page that the form is posting to (where you are displaying the information)? If you don't want the fieldset name to be in the display, you can remove it there.
