Error after adding "Include Directons"
Thread begun 1/31/2010 7:52 pm by fireplug41126928 | Last modified 2/05/2010 12:29 pm by Jimmy Wu | 4907 views | 8 replies |
fireplug41126928
I am having issues with the page working fine until i check the "include Directions" check box and adding the form fields to the boxes. Once i do this when i load the page it gives me an error saying the following
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.0; Trident/4.0; GTB5; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 1.1.4322; .NET CLR 3.5.30729; .NET CLR 3.0.30729)
Timestamp: Mon, 1 Feb 2010 03:49:53 UTC
Message: Object doesn't support this property or method
Line: 267
Char: 5
Code: 0
URI: directions.asp
this is the code from that section of the page:
directions = new GDirections(map, document.getElementById('wagmp_directions_1'));
GEvent.addListener(directions, "error", function() {
map.setCenter(wagmp_map_1_obj.points[0], 13);
map.addOverlay(wagmp_map_1_obj.markers[0]);
directions.load('from: ' + fromAddress.full + ' to: ' + address_0.full);
wagmp_map_1_obj.directions = directions;
It works fine with out adding the include directions added.
Jimmy Wu
When I access the page, I am not getting the same error that you are. What version of FireFox are you using to access the page?
fireplug41126928
i am using IE8. It was working before then all of a suddenyl stopped working.
fireplug41126928
i am attaching the files with the pages.
Jimmy Wu
I don't see line 267 on the files you sent. Are you sure that the error is referring to that line?
fireplug41126928
that is because the error is occuring on line 267 of the combined file in IE. after internet explorer combines the include file into the code.
this is the error just like i put previous:
Timestamp: Wed, 3 Feb 2010 18:48:41 UTC
Line: 267
Char: 5
Code: 0
URI: directions.asp
I will attach the source code right out of IE8 in a word file, then you can see what i am talking about. I have put (Line 267) in the text at that point so you can see which one it is.
Jimmy Wu
It looks like it may be something else on your page that is causing this issue. Try creating the map on a new blank page and see if the map works for you.
fireplug41126928
well you can disregard this thread now I have figured out what it is. The problem was coming from a image that had a image name of "Directons". so i renamed the of the image and all is well. Thanks for your input though.
Jimmy Wu
Great to hear that you were able to figure out what the cause of the error was. If you run into any additional issues, feel free to open a new thread.
