Why won't this validate? It keeps returning
Thread begun 1/31/2010 7:47 pm by larry289409 | Last modified 2/04/2010 6:46 am by larry289409 | 4507 views | 5 replies |
larry289409
I started with the DataAssist wizard, which made me a users_insert and a users_detail.
I seem to have set up the server validations correctly. No matter what I put in, I keep getting the page returned for correction. I have attached a screen shot of the form.
Thanks.
Larry
<?php require_once("Connections/Premiere.php"); ?>
<?php require_once("WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once("WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php require_once("WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$WAFV_Redirect = "users_Detail.php";
$_SESSION['WAVT_usersInsert_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateRQ(((isset($_POST["UserFirstName"]))?$_POST["UserFirstName"]:"") . "",false,1);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["UserLastName"]))?$_POST["UserLastName"]:"") . "",false,2);
$WAFV_Errors .= WAValidateEM(((isset($_POST["UserEmail"]))?$_POST["UserEmail"]:"") . "",true,3);
$WAFV_Errors .= WAValidatePN(((isset($_POST["UserPhone"]))?$_POST["UserPhone"]:"") . "",true,false,false,4);
$WAFV_Errors .= WAValidatePN(((isset($_POST["UserPhoneM"]))?$_POST["UserPhoneM"]:"") . "",true,false,false,5);
$WAFV_Errors .= WAValidateAN(((isset($_POST["JobType"]))?$_POST["JobType"]:"") . "",true,true,true,true,"",true,6);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"usersInsert");
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $Premiere;
$WA_table = "users";
$WA_sessionName = "WADA_Insert_users";
$WA_redirectURL = "/users_Detail.php";
$WA_keepQueryString = false;
$WA_indexField = "UserID";
$WA_fieldNamesStr = "UserEmail|UserPassword|UserFirstName|UserLastName|UserCity|UserState|UserZip|UserEmailVerified|UserRegistrationDate|UserVerificationCode|UserIP|UserPhone|UserPhoneM|TimeToCall|UserFax|UserCountry|JobType|JobNotes|UserAddress|UserAddress2";
$WA_fieldValuesStr = "".((isset($_POST["UserEmail"]))?$_POST["UserEmail"]:"") ."" . "|" . "".((isset($_POST["UserPassword"]))?$_POST["UserPassword"]:"") ."" . "|" . "".((isset($_POST["UserFirstName"]))?$_POST["UserFirstName"]:"") ."" . "|" . "".((isset($_POST["UserLastName"]))?$_POST["UserLastName"]:"") ."" . "|" . "".((isset($_POST["UserCity"]))?$_POST["UserCity"]:"") ."" . "|" . "".((isset($_POST["UserState"]))?$_POST["UserState"]:"") ."" . "|" . "".((isset($_POST["UserZip"]))?$_POST["UserZip"]:"") ."" . "|" . "".((isset($_POST["UserEmailVerified"]))?$_POST["UserEmailVerified"]:"") ."" . "|" . "".((isset($_POST["UserRegistrationDate"]))?$_POST["UserRegistrationDate"]:"") ."" . "|" . "".((isset($_POST["UserVerificationCode"]))?$_POST["UserVerificationCode"]:"") ."" . "|" . "".((isset($_POST["UserIP"]))?$_POST["UserIP"]:"") ."" . "|" . "".((isset($_POST["UserPhone"]))?$_POST["UserPhone"]:"") ."" . "|" . "".((isset($_POST["UserPhoneM"]))?$_POST["UserPhoneM"]:"") ."" . "|" . "".((isset($_POST["TimeToCall"]))?$_POST["TimeToCall"]:"") ."" . "|" . "".((isset($_POST["UserFax"]))?$_POST["UserFax"]:"") ."" . "|" . "".((isset($_POST["UserCountry"]))?$_POST["UserCountry"]:"") ."" . "|" . "".((isset($_POST["JobType"]))?$_POST["JobType"]:"") ."" . "|" . "".((isset($_POST["JobNotes"]))?$_POST["JobNotes"]:"") ."" . "|" . "".((isset($_POST["UserAddress"]))?$_POST["UserAddress"]:"") ."" . "|" . "".((isset($_POST["UserAddress2"]))?$_POST["UserAddress2"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|none,none,NULL|',none,NULL|',none,''|',none,''|',none,''|',none,''|none,none,NULL|',none,''|',none,''|none,none,NULL|',none,''|',none,''|',none,''";
$WA_connectionDB = $database_Premiere;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
?><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1" />
<title>Insert users</title>
<link href="/WA_DataAssist/styles/Arial.css" rel="stylesheet" type="text/css" />
<style type="text/css">
@import url("WA_DataAssist/styles/Refined_Pacifica.css");
</style>
</head>
<body>
<div class="WADAInsertContainer">
<form action="users_Detail.php" method="post" name="WADAInsertForm" id="WADAInsertForm">
<div class="WADAHeader">Insert Record</div>
<div class="WADAHorizLine"><img src="/WA_DataAssist/images/_tx_.gif" alt="" height="1" width="1" border="0" /></div>
<table width="686" border="0" cellpadding="0" cellspacing="0" class="WADADataTable">
<tr>
<th class="WADADataTableHeader">&nbsp;</th>
<td colspan="2" align="center"class="WADANoResultsMessage"><?php
if (ValidatedField('usersDetail','usersDetail')) {
if ((strpos((",".ValidatedField("usersDetail","usersDetail").","), "," . "" . ",") !== false || "" == "")) {
if (!(false)) {
Please review and fill in the items noted below
<?php //WAFV_Conditional users_Detail.php usersDetail( 3: )
}?></td>
</tr>
<tr>
<th width="202" class="WADADataTableHeader">First Name:</th>
<td width="276" class="WADADataTableCell"><input name="UserFirstName" type="text" id="UserFirstName" value="<?php echo(ValidatedField("usersDetail","UserFirstName")) ?>" size="32" /></td>
<td width="649"> <span class="WADANoResultsMessage">
if ((strpos((",".ValidatedField("usersDetail","usersDetail").","), "," . "2" . ",") !== false || "2" == "")) {
if (!(false)) {
We need your first name
<?php //WAFV_Conditional users_Detail.php usersDetail(2: )
}?></span></td>
</tr>
<tr>
<th class="WADADataTableHeader">Last Name:</th>
<td class="WADADataTableCell"><input type="text" name="UserLastName" id="UserLastName" value="<?php echo(ValidatedField("usersDetail","UserLastName")) ?>" size="32" /></td>
<td class="WADANoResultsMessage"><?php
if ((strpos((",".ValidatedField("usersDetail","usersDetail").","), "," . "3" . ",") !== false || "3" == "")) {
if (!(false)) {
We need your last name
<?php //WAFV_Conditional users_Detail.php usersDetail(3: )
}?></td>
</tr>
One problem I can see is that the form action is set to go to the users_Detail.php page. the action should be left blank so that the form will post to itself. you will need to redo the validation show if behaviors, and choose the users_insert page as the validation page.
larry289409
Where is documentation for this process?
Where do I find docs that will tell me the best way to get a Thank you Page to show?
larry289409
Partial improvement
Here's what I have now. The validation messages don't go away, and nothing shows up on the Details page. However, the values are kept after inserting, and if all values are correct, we are taken to the Details page.
$WAFV_Redirect = "users_Insert.php";
$WAFV_Errors = "";
<head>
</style>
</head>
<body>
<form action="" method="post" name="WADAInsertForm" id="WADAInsertForm">
<table width="686" border="0" cellpadding="0" cellspacing="0" class="WADADataTable"><tr><td class="WADANoResultsMessage"><table width="686" border="0" cellpadding="0" cellspacing="0" class="WADADataTable">
<tr>
if (ValidatedField('usersInsert','usersInsert')) {
if ((strpos((",".ValidatedField("usersInsert","usersInsert").","), "," . "" . ",") !== false || "" == "")) {
if (!(false)) {
<?php //WAFV_Conditional users_Insert.php usersInsert( :)
}?></td>
</tr>
<tr>
<td width="276" class="WADADataTableCell"><input name="UserFirstName" type="text" id="UserFirstName" value="<?php echo(ValidatedField("usersInsert","UserFirstName")) ?>" size="32" /></td>
<td width="649"><?php
if ((strpos((",".ValidatedField("usersInsert","usersInsert").","), "," . "2" . ",") !== false || "2" == "")) {
if (!(false)) {
<?php //WAFV_Conditional users_Insert.php usersInsert(2:)
if ((strpos((",".ValidatedField("usersInsert","usersInsert").","), "," . "") >= 0)) {
if (!((strpos((",".ValidatedField("usersInsert","usersInsert").","), "," . "1" . ",") !== false || "1" == ""))) {
xxxxxx
<?php //WAFV_Conditional users_Insert.php usersInsert(:1)
}?></td>
</tr>
<tr>
<td class="WADADataTableCell"><input type="text" name="UserLastName" id="UserLastName" value="<?php echo(ValidatedField("usersInsert","UserLastName")) ?>" size="32" /></td>
if (!(false)) {
}?></td>
login.php
larry289409
I solved problem myself
No need for a support ticket on this one. I was lucky enough to manage to figure this one out by trial and error, and with a very little bit of help from help files.
