Report in Dreamweaver.
Is or will be available in the future an extension for print a report in PDF (for print e.g a tabular data grid)??
Massimo
Massimo
Not sure what exactly you're requesting. Do you mean something like Dynamic Web Charts but will make a pdf file based on dynamic data instead of a flash chart?
Did you want this ability added to your site or just being able to generate them within Dreamweaver?
Jimmy, I mean generate a PDF report (no Web Chart) when passing dynamic data from a tables or queries used in a db. I have already asked to Adobe support for include this feature in the next release (CS5) but the answer is "DW is for build/edit a Web Site not for generate a report".
Massimo
The development team will take a look at this idea to decide if it is viable to implement as a future product or not. Thank you for submitting your idea.
