only centre column to be editable (sculptor 3)
Thread begun 1/29/2010 7:39 pm by eldados399361 | Last modified 1/29/2010 9:20 pm by neilo | 1276 views | 1 replies |
eldados399361
Hi there,
I am trying to create a 3 column with header and footer @ 1200pix wide and 800 high to be centred on a page, all is good but I only want the main content to be editable, I need the left and right columns to stay static.
I can't select the main content alone.
thanks for your help
neilo
Hiya,
I'm not sure why you can't select just the centre content area to be editable.
Once you have saved your document as a Template (Dreamweaver Menu > File > 'Save as Template') then you should be able to place your cursor in the middle of your content area div (inside the dotted lines of the div) and select <div#content> from the elements info bar just above the properties panel/inspector to select the div.
Then from the Dreamweaver Menu, select > Insert > Template Objects & select 'Create Editable Region'.
This will then be the only area that will be editable unless you add new editable regions to the template.
Click to save the template, and when if it asks you if it should update the links, click 'yes'.
