Reset Dropdown List in Search Form
Thread begun 1/29/2010 4:42 pm by jurinski334466 | Last modified 12/02/2014 6:51 am by lrgraphics315137 | 6281 views | 7 replies |
jurinski334466
I have a search form on the results page where I am having trouble clearing the value in the dropdown list. I would like to keep the selected value during a search but also be able to clear and reset the form so all results show, and the list returns to the default position. Is this possible?
I tried clearing the session variable with a link and clear=true on the results page, and on the results page and the search page, and also trying to use a separate page to try to reset the list. I think the problem maybe the recordset select statement which includes an AS column.
mysql_select_db($database_newbbcpeConn, $newbbcpeConn);
$query_WADADynListendtimelist = "SELECT endtimelist.EndTimeListID, endtimelist.EndTime, TIME_FORMAT( endtimelist.EndTime, '%l:%i %p') AS EndingTime FROM endtimelist ORDER BY endtimelist.EndTime ASC";
setQueryBuilderSource($query_WADADynListendtimelist,$WADbSearch1,false);
$query_limit_WADADynListendtimelist = sprintf("%s LIMIT %d, %d", $query_WADADynListendtimelist, $startRow_WADADynListendtimelist, $maxRows_WADADynListendtimelist);
$WADADynListendtimelist = mysql_query($query_limit_WADADynListendtimelist, $newbbcpeConn) or die(mysql_error());
$row_WADADynListendtimelist = mysql_fetch_assoc($WADADynListendtimelist);
How do I reset the search so that when the search button is pressed it loads all the
results and resets the dynamic list to the default selected value?
Thank you for any help.
The way that DataAssist works is through the trigger you specify. When this trigger is encountered the search values will be stored in a session variable. The search will show these results anytime that you browse to this results page without triggering a new search.
To clear a previous set of results you just need to trigger the search without any values specified.
What do you have the trigger setup as? Also, how would you like the user to reset the results to get back all of them? Do you want them to click on a show all button or something like that?
jurinski334466
Thanks for your reply.
The search form works great for searching the data; however, I also need to have either a link or a button which clears the search and shows all the results and resets the dropdown list to its default value.
I'm sorry, but I'm not sure what the trigger for the search/results page is called. Where in the code do I find that value?
Right now, I am trying to clear the search using this link added to the form:
<a href="endtime-results.php?clear=true"><em>ResetSearch</em></a>
And this code at the top of the page:
if(!session_id()) session_start();
if(isset($_SESSION["WADbSearch1_endtimeresults"]) && isset($_GET['clear']) && $_GET['clear'] == "true") {
unset($_SESSION["WADbSearch1_endtimeresults"]);
This link works to clear all the search results but does not clear the dropdown list. Instead, the dropdown list returns to the first recordset value of 11:00 am and not the default value of "Search Ending Times."
This is the code for the dropdown list:
<select name="S_EndTime" id="S_EndTime">
<option value="" <?php if (!(strcmp("", $row_WADAendtimelist["EndTime"]))) {echo "selected=\"selected\"";} ?>>Search Ending Times</option>
do {
do {
<option value="<?php echo $row_WADADynListendtimelist['EndTime']?>"<?php if (!(strcmp($row_WADADynListendtimelist['EndTimeListID'], $row_WADAendtimelist["EndTimeListID"]))) {echo "selected=\"selected\"";} ?>><?php echo $row_WADADynListendtimelist['EndingTime'] ?></option>
} while ($row_WADADynListendtimelist = mysql_fetch_assoc($WADADynListendtimelist));
$rows = mysql_num_rows($WADADynListendtimelist);
if($rows > 0) {
mysql_data_seek($WADADynListendtimelist, 0);
</select>
I would appreciate help figuring out how to completely clear the search. Thank you.
Since you are able to clear the results out you should be able to get the select list to show the first value as selected by adding in the selected attribute to the first option like this:
<option value="" selected="selected">Search Ending Times</option>
You might still have this problem though if there are any matches from the recordset that you are working with in the list. Please post back with the page in question in a zip archive and I will take a look to let you know how you can get this other recordset to not have any values initially.
jurinski334466
Thanks Eric, for taking a look at the page. I appreciate your help as I'm in over my head...
I changed the select list as you suggested. Now the dropdown list and the results list clear, but search and list values are no longer retained in the dropdown list.
I also tried editing the search statements and changing the Dynamic list values to see whether this affected the result.
I am trying to get this form field working before incorporating it into another form or at least get the form working independently.
I sent you both the results, and the search page, in the attached zip file. Please let me know if you need anything more.
Thanks again for your help.
I'm having a hard time understanding what is not working correctly in the search and results pages. Do you have a link that I can use to see this? I think this would be best.
In general you should be able to set the contents of a select list from a recordset. If you want to show what selection was made you can use the dynamic property in the property inspector to set the selected value to a value from a recordset or a posted value. If you are setting it to be initially selected based on a recordset value and it is not being reset it is because the recordset is still returning the same value.
lrgraphics315137
Hi Eric
You have to clear S_Endtime after the search and before the dynamic list. If you need to keep the info for some other code pass the info to a temp variable and use that variable for the other code see below
AFTER SEARCH CODE
if ($_GET['S_EndTime'] != "") {
$S_EndTimeX = $_GET['S_EndTime']; // pass to temp variable if need variable contents
$_GET['S_EndTime'] = ""; // clear variable
BEFORE DYNAMIC LIST
lrgraphics315137
RESET DYNAMIC <SELECT> LIST
No It's not the result he wants to reset it's the dynamic drop down list he wants to reset!!!!!!!!!
I have the same problem on one of my clients sites. On the products results page I have search parameters on the left col, and a menu selection at top when hovering products link. now if you select a menu main group item it sets the search param to S_prodGroupID=5 say then goes to results page shows the products with a group ID of 5 OKAY.
But then if you go to the left col to select another group selection the drop down list only shows from item 5 down.
How after getting the results for the first search do you reset the drop down list???????
Website: www.aworldoffires.co.uk
