Formatting date fields (.asp)
Thread begun 1/29/2010 8:15 am by suarezm129397438 | Last modified 2/08/2010 5:17 pm by Jason Byrnes | 3073 views | 4 replies |
suarezm129397438
In my DataAssist update form I have a date and time field that is not editable but displays on the form. How do I format these two fields so that they display correctly?
This is the code on the update form:
<tr>
<th class="WADADataTableHeader">Enroll Date:</th>
<td class="WADADataTableCell"><%=String(WADAparticipant_data.Fields.Item("enroll_date").Value==null?"":(WADAparticipant_data.Fields.Item("enroll_date").Value)).replace(/"/g, '&quot;')%></td>
</tr>
<tr>
<th class="WADADataTableHeader">Enroll Time:</th>
<td class="WADADataTableCell"><%=String(WADAparticipant_data.Fields.Item("enroll_time").Value==null?"":(WADAparticipant_data.Fields.Item("enroll_time").Value)).replace(/"/g, '&quot;')%></td>
</tr>
This is how the date and time field display on the form:
Date: Thu Jan 28 00:00:00 EST 2010
Time:Sat Dec 30 21:43:31 EST 1899
The date and time on the access database are:
Date: 1/28/2010
Time: 9:43:31 PM
I'm not very familiar with date formatting in asp but if you can post a sample of the data you are working with in an access db I can try to see if can get the date formatting differently or if there is another way to go about it.
change your code:
<tr>
</tr>
<tr>
</tr>
<tr>
<td class="WADADataTableCell"><%=String(WADAparticipant_data.Fields.Item("enroll_date").Value==null?"":DoDateTime((WADAparticipant_data.Fields.Item("enroll_date").Value)).replace(/"/g, '&quot;'), 2, 1033)%></td>
</tr>
<tr>
<td class="WADADataTableCell"><%=String(WADAparticipant_data.Fields.Item("enroll_time").Value==null?"":DoDateTime((WADAparticipant_data.Fields.Item("enroll_time").Value)).replace(/"/g, '&quot;'), 3, 1033)%></td>
</tr>
suarezm129397438
I made the changes you suggested but now I'm getting this error:
______________________________________________
HTTP 500.100 - Internal Server Error - ASP error
Internet Information Services
Technical Information (for support personnel)
Error Type:
Microsoft JScript runtime (0x800A138F)
Object expected
Help!
try this instead:
<tr>
<td class="WADADataTableCell"><%=DoDateTime(String(WADAparticipant_data.Fields.Item("enroll_date").Value==null?"":(WADAparticipant_data.Fields.Item("enroll_date").Value)).replace(/"/g, '&quot;'), 2, 1033)%></td>
</tr>
<tr>
<td class="WADADataTableCell"><%=DoDateTime(String(WADAparticipant_data.Fields.Item("enroll_time").Value==null?"":(WADAparticipant_data.Fields.Item("enroll_time").Value)).replace(/"/g, '&quot;'), 3, 1033)%></td>
</tr>
