unknown warning
Thread begun 1/29/2010 7:06 am by jaa397769 | Last modified 2/01/2010 1:35 pm by jaa397769 | 4518 views | 10 replies |
jaa397769
unknown warning
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/r/u/t//html/shop/index.php:3) in /home/content/r/u/t//html/shop/WA_eCart/WA_eCart_Definition_PHP.php on line 479
Please help, I have no idea why my home page will not view right anymore. This is the error Im receiving in my browser. Thank you.
Office Guy-172461
Have a look here:
Solving the "headers already sent" problem
148/
jaa397769
Excellent
Thank you so much for quick and easy to understand response. A real value to this community you are.
Office Guy-172461
Thanks for your kind words. :)
neilo
Hiya,
You are also getting extra error messages about a missing connection file.
Assuming that your site is ruttandstrutt.com, then your shop/CSSMenuWriter/cssmw_home/menu.php is looking for the Connections folder in the wrong place.
The menu.php page is pointing to it at: ../../../Connections/powerstore.php, i.e. it is looking for the Connections folder in the root directory, however it seems that your Connections folder is inside the 'shop' folder, not the root directory.
You should change the path to the connections folder in your 'shop/CSSMenuWriter/cssmw_home/menu.php' file to point to yoursite.com/shop/Connections/powerstore.php.
jaa397769
should i just
should I just move the folder neilo? Or change the code? If so what file am I looking to make a change in. Thanks so much for your help.
neilo
Hiya J,
You won't have to move the folder but you may have to make a change to one of your files.
Please could you have a look at the 'WA_Globals.php' file (which should be at 'shop/WA_Globals/WA_Globals.php).
As far as I can tell, the settings in that file may be wrong. They should look something like this:
$WAGLOBAL_Root_URL = "http://www.ruttandstrutt.com/shop/" ;
$WAGLOBAL_Site_Name = "Rutt and Strutt - Store" ;
$WAGLOBAL_Address = "Your Adress for Google Maps";
$WAGLOBAL_City = "Your City";
$WAGLOBAL_State = "MO";
$WAGLOBAL_Zip = "65775";
$WAGLOBAL_Country = "US";
$WAGLOBAL_GoogleAPIKey = "ABQIAAAAXafbUiGiRYj0bogExLhVCRT2yXp_ZAY8_ufC3CFXhHIE1NvwkxT5czkOfeMRZCjwJ7_QG4gFmJ1OGQ";
$WAGLOBAL_localRoot = "/shop/";
$WAGLOBAL_remoteRoot = "/shop/";
The important lines here are the first line and the last two lines. If your lines are different, please could you try substituting the above, and give it a try?
Let us know how it goes.
jaa397769
but
$WAGLOBAL_Root_URL = "http://www..com/shop/" ;
This website is set up in a 'sub' domain named "Shop"
so when you web to it, it's shop..com
Therefore I have the line reading as such
$WAGLOBAL_Root_URL = "http://shop..com/" ;
should I change it to?
$WAGLOBAL_Root_URL = "http://www.com/shop/" ;
Also the other two lines you referenced are just
$WAGLOBAL_localRoot = "/";
$WAGLOBAL_remoteRoot = "/";
not
jaa397769
I did try that
Neilo, I tried making those changes, when I did, I went to do a paypal transaction to test and I got an error pointing to that ../connections/menu.php so I changed it back and the transaction worked.
Why do you think it is working the way I have it if it is wrong?
Just curious.
Thanks again for all your help. Much appreciated.
J
neilo
Hi J,
You have it absolutely right, I had it wrong. I jumped to a conclusion and fell several folders short.
I made an assumption - based on your first post - that your store would be at yoursite.com/shop/, and when I checked out what appeared to be a problem I didn't stop to think of the alternatives. I seem to be making a habit of that lately.
I apologise for wasting your time,
neilo
