Update error
always recive the same error when I try to update.
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'ONLINEundefined, `FAM_ORDEN` = 1, `FAM_ACTIVA` = 1, `FAM_PLANTILLA` = 1, `FAM_IM' at line 1
and this when I try to insert
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'Familiaundefined,2,1,1,undefined01.jpgundefined)' at line 1
