Another IE6 problem - I'm affraid
Thread begun 1/28/2010 3:59 pm by peterlethbridge399499 | Last modified 1/29/2010 5:33 am by neilo | 2984 views | 5 replies |
My Website: createorder.php
I want to align the menu to the right, so I put the PHP menu include into a div container. This seems to work for everything but IE6 where the menus now display under other elements on the page. If I take it out of the div it works fine, but then I can align it.
Could someone please help. This is the only remaining issue I have (or at least I hope!).
Many thanks
Peter
neilo
Hi Peter,
Looking good.
In your stylesheets/main.css file, add padding-left to the menubar class:
.menubar {
background-image:url(../images/header_bottom.jpg);
background-repeat:no-repeat;
display:inline-block;
width:672px;
padding-left: 228px;
You may need to play with the padding width a little. Still looking at the IE6 bit.
Edit: Oops, - and reduce the width to 672px!
thanks Neil
I notice that IE7 has the same issue.
neilo
This has been driving me bananas.
I thought a simple z-index would bring them out, - the menu drop-downs were disappearing behind other page elements, and no amount of z-index juggling would sort it for IE7 or IE6.
But at or around line 375-381 of your main.css stylesheet, you have a block of css rules for (just) 'div'; - I'm not sure why you have a generic set of rules for 'div', but if you remove the last rule - position:relative; - this seems to release the menu include div from captivity and allows the menu to drop-down over the other page elements. This should render OK on screen - but things may go a bit haywire in design-view. You may have to apply position rules to individual div IDs or create a new class. Or just leave it.
So that (main.css) div css should now look like this:
div {
margin:0px;
padding:0px;
font-family:verdana;
font-size:12px;
color:#286206;
I also added a:
z-index: 999;
property to the end of the following blocks of css in menu.css (for the hell of it):
ul#cssmw {
ul#cssmw > li > span > a {
ul#cssmw ul.level-1 {
ul#cssmw ul.level-1 > li > a {
ul#cssmw ul.level-2 {
ul#cssmw ul.level-2 > li > a {
This seems to sort things out in IE7, and I'm getting intermittent results for IE6 in Browser Lab (I don't have IE6 on my Machine) sometimes see 5 menu items , sometimes 2, sometimes all, so hope it helps.
You are the MAN!!
Thankyou so much for this Neil. The DIV was put their by fireworks when I exported the page design. I never gave it much thought.
Thankyou again. Great support.
neilo
Cheers Peter, - it's looking good from this end.
