Captcha
Thread begun 1/28/2010 12:28 pm by woodenboat | Last modified 1/29/2010 9:23 am by woodenboat | 2072 views | 2 replies |
woodenboat
Captcha
I'm finding that users do not like to go through both the CaptchaSecurityImage plus the CaptchaSecurityQuestion.
So I would like to remove the CaptchaSecurityImage and only use the CaptchaSecurityQuestion. But I can't fine any guide or how-to that shows me how to delete it without causing errors. I'm hoping you can point me in the right direction.
Dani Chankhour
There is a few things that needs to happen to get this working correctly:
1. first remove the input field and captcha image in Dreamweaver (you can use design view)
2. you will need to remove the spry validation at the bottom of the page:
var sprytextfield9 = new Spry.Widget.ValidationTextField("sprytextfield9", "none", {minChars:5, maxChars:5, validateOn:["blur"]});
3. remove the server side validation at the top of the page:
$WAFV_Errors .= WAValidateLE(((isset($_POST["Security_code"]))?strtolower($_POST["Security_code"]):"") . "",((isset($_SESSION["captcha_1"]))?strtolower($_SESSION["captcha_1"]):"") . "",true,7);
This should remove the captcha.
woodenboat
Yes, that worked, thanks.
