ÄÜÖß do not work in UW
Thread begun 1/28/2010 11:06 am by hh325582 | Last modified 1/29/2010 5:18 pm by Eric Mittman | 2562 views | 3 replies |
hh325582
Umlaute are not shown correct in Outlook
This are the entries
Contact Name: üüüüüüü
Email address: frh@sfdg.net
Comments: öüß öüß
this is the result
Comments: öüß öüß
server delivers utf-8
Thanks for Your help
You will probably need to adjust your charset, have you tried using ISO-8859-1? I think this is the one that should be used to support the characters.
hh325582
not so easy
Changed contactus.php & template & server to iso-8859-2 does work in Outlook, does not work in Zimbra
Changed contactus.php & template to utf-8 & server to iso-8859-2 to does work in Outlook, does not work in Zimbra
Any ideas?
I think the charset should be ISO-8859-1. You may need to update the local setting of your server. You can do this in php with the setlocale() function. Here is a ling to functions page on php.net:
function.setlocale.php
I think you would want to set it like this:
setlocale(LC_ALL, 'de_DE@euro', 'de_DE', 'de', 'ge');
This is an example from the php page. If you are still having problems you should check in the email message to see if you can find the encoding or charset. It may have to do with your mail servers settings as well.
