Google map code throwing off other code in my page
Thread begun 1/28/2010 9:12 am by sandy170299 | Last modified 2/04/2010 3:59 pm by Jimmy Wu | 4318 views | 7 replies |
sandy170299
The Google map is throwing off the other code in my page and is messing up my listing/results table formatting. I know that it's the Google code that is doing it, because when I remove the javascript and the map, the results table is formatted just fine. When I add the Google map code back into the page, it throws off my table formatting again. What could be causing this?
hunting.php?state=WI
Jimmy Wu
Can you copy the page and remove the map and host that page as well, so I can see the difference?
sandy170299
Jimmy, here is the page with ALL the map-related code removed.
hunting2.php?state=WI
As you can see, the table aligns correctly now.
Jimmy Wu
I can see that. How is the table generated? Is it a dynamically created table?
sandy170299
Yes, it is dynamically generated. It's using the same query that the map uses. The reason I'm doing this is because at the zommed out distance of the map, locations that are close to each other appear to be on top of each other, and you can't tell them apart.
Jimmy Wu
What does your table generation code look like?
sandy170299
Here is the entire page as a text document.
Jimmy Wu
Looks like the order of the addresses is also getting affected by the map. You could also try putting the table for the addresses in a separate div to see if the alignment is caused by being in the same div as the map.
As a test you can try putting the table code above the map as well so that it will get called first to see if that affects the outcome.
I don't see anything that should cause the alignment problems though.
