Mutiple Price function or adding subcategories under products
Thread begun 1/28/2010 8:44 am by cj.tung395641 | Last modified 2/01/2010 6:46 am by cj.tung395641 | 2377 views | 4 replies |
cj.tung395641
Hello,
My boss would need to have some options for customer when choose products, and the price will also need to be changed when customers choose different options. For instance, same product but bigger size of the product is more expansive and the smaller size is cheaper...etc.
I wonder how can I fix this problem?
or I can also use another way by adding subcategories under products.
IF you can provide me any idea that would be great helpful!
Thank you.
chunjhen
Dani Chankhour
What version of PowerStore are you using?
cj.tung395641
This post has been deleted.
cj.tung395641
Originally Said By: Dani Chankhour
Thanks Mr. Chankhour! I have got your answer from the other reply. After I read the getting started guide again and try many ways to change the price list and options for the product, it seems worked!
Just wonder if in the future will there be a new function to alter SKU as well. For example, each product options obtain unique codes, then when customers choose different colors, size... at the end SKU will generated by collecting order code by the order of options. (Please take a look at the attachment for better understanding). Thanks.
Dani Chankhour
If you are using PowerStore v2, then you should be able to change the SKU for each options. Basically on your product update page, you should see the product options listed on the top of the page. By default, the default option is shown, but if you want to change the sku for a different option, just select the option from the list and update the sku and then click the update button. This will update the SKU for that specific product options.
cj.tung395641
Thank you Dani! It works very well.
