Error on Insert Theme-It
Thread begun 1/28/2010 8:36 am by ryan298919 | Last modified 1/30/2010 9:07 am by David Stringer | 3966 views | 8 replies |
ryan298919Beta Tester
After activating Theme-It, when I try to use it via the Insert > WebAssist > Theme-It menu, I get the following error in CS4:
While executing onLoad in wa_themeit.htm, the following JavaScript error(s) occurred:
At line 845 of file C:\Program Files\Adobe\Adobe Dreamweaver CS4\Configuration\Commands\wa_themeit.js": imageURL has no properties
Dani Chankhour
Thanks.
Could you send me the CSS Include file so i can test with it on my end.
What CSS file?
Dani Chankhour
From the error you reported, it seems that the error happened when trying to read a css include file on your page.
If you can send me a link to the page you ran Theme-It on instead that would be great.
thanks.
Here's the style sheet. style.css
I'll do some testing on this end to see if I can figure out what's causing the error too.
Justin HoodWebAssist
Thank you for your valuable feedback. This cause of this issue has been identified and a fix should be in the next beta build.
Thanks again!
Any idea when the next beta will be available?
Ann Luong
Hi Ryan,
A new build should be available early next week. Thanks for your participation!
David StringerBeta Tester
Same As
Originally Said By: Ann Luong
  Hi Ryan,
I look forward to testing the new build as I have found the same problem reported above.
