Error when installing Security Assist
Thread begun 1/28/2010 7:00 am by musloffice398578 | Last modified 1/28/2010 4:35 pm by Office Guy-172461 | 3828 views | 6 replies |
musloffice398578
I get the following error message when I try to install Security Assist: "Can not update a file, the extension will not be installed".
Office Guy-172461
See section 2:
Solving problems with Dreamweaver
146/
musloffice398578
Unable to install Security Assist
I have 3 different folders titled "Configuration", I'm new at this and I'm a little bit unsure of deleting these files. Here is a list of these configuration folders.
Users/MyName/Library/Application Support/Adobe/Dreamweaver/Configuration
Users/MyName/Library/Application Support/Adobe/Extension Manager/Configuration
Applications/Dreamweaver/Configuration
Larry
Office Guy-172461
I assume you are on a Mac.
Go to the Mac section.
Follow the guide to the version of DW you have, and rename that folder. That way if you get the wrong one, you can just rename it back to the original name.
You only want the folder under Dreamweaver.
See the warning (in red) in that section.
musloffice398578
Yes, I'm on the Ma. I've disabled all of the WebAssist extensions and tried to download the Security Assist extension. I'm getting a message that says a newer folder already exists. I'm confused.
Office Guy-172461
If I understand what you're saying:
See the Common Alerts section of this guide:
Office Guy-172461
Originally Said By: musloffice398578
  I've disabled all of the WebAssist extensions and tried to download the Security Assist extension..
Disabling is not the same as uninstalling. Please read this carefully before you cause yourself more grief:
146/
