Sending different emails to different people
Thread begun 1/27/2010 11:11 am by mikesp293892 | Last modified 1/28/2010 6:35 pm by Dani Chankhour | 3748 views | 5 replies |
mikesp293892
I am just learning the Web Assist software but have been hand coding for years. I have just recieved a rush job and can't figure this one out.
I need to be able to:
Send an email to the person who filled the form saying Thanks (I can get that to work ok)
Send an email to people in the office with the info from the form
AND
Send the info to a database.
Any help would be appreciated
Judy Perry
Dani Chankhour
First you will need to create a record set that returns the list of the emails of the people in the office. Then in Universal Email, you could use the BCC tab, which allows you to send a BCC email, and select record set loop. this will send the email to the office list in a separate email.
To save the form in a database, you will need to use an Insert Server Behavior which is included in DataAssist. This will allow you to insert data to your database when the form is submitted.
mikesp293892
text file rather than database
the client doesn't want a database to hold the form info, they want a
comma delimited (with quotes) text file that includes the "Date" and "IP" when the form was filled out.
How do I set that up?
Dani Chankhour
Do you have DataAssist and Do you have your database set up already, or do you need help with creating the table as well?
mikesp293892
Yes, I have Data Assist, and don't have the database & table set up.
Dani Chankhour
OK, so the first step is set you your database.
You will need three columns: ID, date, and IP.
the id is the primary key with auto increment, and date is a timestamp and set the default to CURRENT_TIMESTAMP, and the ip is a varchar 250.
Next, you will then add the DataAssist Server Behavior, and after you select you table on step 2 when you bind the values, leave the id and date blank and for the IP, set the value to:
$_SERVER['REMOTE_ADDR'];
This will store the needed information in your database. As far as saving the data to a text file, i think that would require a little bit of work and some custom coding, but here is a link that could help you get started
file_write_php.htm
