Unable to Insert Multiple Records - Error!
Thread begun 1/26/2010 8:56 pm by scott399397 | Last modified 3/25/2010 7:37 am by rmurphy6261468 | 4360 views | 7 replies |
scott399397
I'm trying to insert multiple records in a small test page before tackling a larger, more complex page; I receive the following error after clicking 'Submit':
Error Type:
Microsoft VBScript runtime (0x800A01F5)
Illegal assignment: 'WA_AB_checkLoopedFieldsExist'
/WA_DataAssist/WA_AppBuilder_VB.asp, line 55
I've attached the .asp code...
Thanks!
Scott
scott399397
Thought I found a fix, but still have an issue...
I found and implemented the fix from a previous post; the WA_AppBuilderVB.asp had a typo where you had to add 'InsertMulti' to two lines.
That part corrected the error, however, now although I don't get an error, It also doesn't actually Insert anything into the database!!
Aly help would be greatly appreciated!
Thanks,
Scott
It looks as though you are redirecting to a thank you page. Do you get to this page? If you are not getting to this page it would indicate that the server behavior is not triggering or it is triggered and fails. I have added a debug statement so that we can see the query code that is attempting to be executed. I think this will be the first thing that should be checked, this should give us a clue about what is going wrong. Please give this a try and let us know what the result is.
scott399397
No Luck Yet...
Yes, it does go to the ThankYou page; it appears to work as intended, but it never actually inserts anything! I tried the page with the query you included, it didn't seem to do anything different. Do you need me to send that file back to you?
What should we try next?
Thanks...
I have opened a ticket for you on this issue so that we can exchange some more files in private. To update the ticket login to WebAssist.com and visit your support history.
rmurphy6261468
Resolution?
I'm having the same issue. Is there a resolution?
Originally Said By: scott399397
Error Type:
Thanks!
Scott
I have opened a ticket for you on this issue. To check on the ticket or update it login and visit your support history.
rmurphy6261468
Multiple Insert Solution
Hi Eric:
This solution worked perfectly for me!
showpost.php?p=29363&postcount=10
