£ symbol appearing on right
Thread begun 1/26/2010 2:23 pm by sales356151 | Last modified 1/27/2010 3:16 pm by Dani Chankhour | 3505 views | 5 replies |
sales356151
Im having issues with a cart, for some reason the £ symbol is on the right, Ive checked in the Ecart Setup and its set to Left.
Site is built with PHP.
Can anyone help.
Kind Regards
Jamie Jackson
Dani Chankhour
On Which page is displaying on the symbol on the right?
I did a quick test and it is showing it on the left on all eCart pages.
sales356151
Hi this is the URL to the website: viewcart.php
Basically click on Vehincle Choice, choose any, then click the DET Tuning link, add the item to cart them you should see the issue with the symbols.
Hope this helps
Kind Regards
Jamie Jackson
Dani Chankhour
Thanks, i was able to see the issue. I did a test with eCart and i was not able to reproduce this issue, but we should be able to fix it.
in your WA_eCart folder, please open a file that is name "your ecart name_PHP.php", i believe in your case it could be called "racechip_PHP.php" and in the file, look for this line of code:
new eCart1_Definition
then change the 7th parameter to be a 0. So you are going to see something like this:
new eCart1_Definition("eCart1", 0, "£", "", true, 2, 0, "oz", true, 2, 1, 0);
the 7th parameter in this case is a 0.
Let me know if you have any questions.
sales356151
Here is what I currently have in the line you mentioned, can you see the error in this
$racechip = new racechip_Definition("racechip", 0, "£", "", true, 2, 0, "oz", true, 2, 1, 0);
Dani Chankhour
You definition looks correct.
I have attached an updated WA_eCart_Definition_PHP.php file which is located under your WA_eCart folder, please replace your WA_eCart_Definition_PHP.php file with the attached file.
