Another Receipt Issue...
Thread begun 1/26/2010 10:58 am by denise234045 | Last modified 1/27/2010 1:22 pm by Dani Chankhour | 2219 views | 4 replies |
denise234045
I posted a questions yesterday about PP receipts (waiting reply?)
But along a similar vein....
The I would like to alter the email receipts that customers receive, adding at least the quantities for each item, as well as sku #'s. If possible, I'm guessing that this is what needs to be changed/added to on receipt.php
<td/><?php echo $WA_Store_Cart->DisplayInfo("Name"); ?><br />
<?php echo $WA_Store_Cart->DisplayInfo("Description"); ?></td>
<td ><?php echo WA_eCart_DisplayMoney($WA_Store_Cart, $WA_Store_Cart->DisplayInfo("TotalPrice")); ?></td>
Thanks, as always -
Denise
Dani Chankhour
I believed i answered your previous post. but you are on the right path:
I just want to mention that if you are using the express check out, then you will need to make these changes in the pp_receipt.php which is under the WA_Universal_Email/Template Folder.
denise234045
Thank you - I'll should be able to add the sku's and qty no problem onto both the pp_receipt.php and receipt.php - as I use both.
I left a lengthy-ish response/explanation/question on the other post, which I won't repeat here!!
Thank you so much for your help!
denise234045
Sorry to bug you again!! So it use this:
<tr >
<td><strong style="font-size:16px"><?php echo $WA_Store_Cart->DisplayInfo("Name"); ?></strong><br />
<td><?php echo $WA_Store_Cart->DisplayInfo("Price"); ?></td>
<td><?php echo $WA_Store_Cart->DisplayInfo("Quantity"); ?></td>
<td><?php echo $WA_Store_Cart->DisplayInfo("SKU"); ?></td>
</tr>
I'll get the Name & description, Price, Quantity, sku and Total Price?
Or to properly pull the price should it be:
<?php echo WA_eCart_DisplayMoney($WA_Store_Cart, $WA_Store_Cart->DisplayInfo("Price")); ?>
I can leave item price off, don't actually know if necessary - but as this site is already live I just wanted to make sure before I posted. I've been having to troubleshoot all kinds of other little things....
Dani Chankhour
Thant looks correct, but i would recommend that you test it to make sure it is display correctly.
