no checkout wizard
Thread begun 1/26/2010 9:45 am by bphilow1399308 | Last modified 1/26/2010 1:06 pm by Dani Chankhour | 1987 views | 2 replies |
bphilow1399308
no checkout wizard
everytime i use the check out wizard I get an error
While executing onLoad in WA eCart
CheckoutWizard.htm the following JavaScript error(s)
Occurred:
In file "WA eCart CheckoutWizard":
initializeUI is not defined
then the program locks up
i'm using a mac G5
USPS and paypal was not connecting before this error
bphilow1399308
fix still need help
i figured out the javascript problem,
When i click on the the paypal button it says
Transaction Not Completed
We're sorry
Your PayPal transaction could not be completed.
thank you for your help
Dani Chankhour
It looks you are using Paypal express check out. the first thing to check is to make sure your credentials are correct and then make sure you are using the sandbox if you are using testing credential and not using the sandbox if you are not using the test credentials.
After that we can do a little more debugging to further determine the issue.
