Unable to find file WA_SiteImport_progess.htm
Thread begun 1/26/2010 9:40 am by john.mccarthy130629 | Last modified 1/28/2010 1:18 pm by john.mccarthy130629 | 4283 views | 6 replies |
john.mccarthy130629
After install SiteImport 3.03 Dreamweaver CS4 loads with error message "Unable to find file WA_SiteImport_progess.htm in Configuration/Floaters Directory & Unable to find WA_Site.htm.
I uninstalled version 2 before installing 3.03.
Any suggestions please?
Dani Chankhour
Try deleting your cache file or renaming your configuration folder, here is a link with the steps:
146/
john.mccarthy130629
WA_Site_progesss.htm
Dani, thanks. I tried what you suggested without any success. The files that Dreamweaver is looking for - WA_SiteImport_Progress.htm & WA_Site.htm are not in the Configuration/Floaters folder.
Ther are2 other files called WA_SiteTools_Progress.htm & WA_SiteTools.htm.
Should I try renaming these to the ones Dreamweaver is looking?
John
In Dreamweaver, goto Window -> Workspace Layouts -> Reset '<Your Layout Name>'
I think that will fix it.
john.mccarthy130629
WA_Site_progesss.htm & WA_SiteImport.htm
Thanks Ray, I tried taht but it didn't work - those 2 files are not actually in the Floaters folder anyway.
Regards,
John
They shouldn't be there. The previous version used them, but they are no longer needed. The problem is that DW is looking for them, not that they aren't there.
Usually refreshing the layout will fix the problem, since DW is looking for them based on that window being open when DW was closed. While it was closed you updated Site Import, which deleted the floater since it has been replaced. Now we just need to tell DW to stop looking for it... Looking through this forum it appears a good handful of people have run into the problem.
The good news is it can be ignored and shouldn't effect functionality. But it is annoying. Maybe try changing your workspace layout setting to another mode like "designer" or "developer" and then close DW and clear the filecache.dat file before opening it again.
The problem is that DW has in its memory that that window was open in your layout and wants to return your view to what you had before, but that window has been replaced by one with a different name in the new version you installed.
You could always install the old version, open DW, then make sure to close the progress window before closing DW and installing the newer version, but that really shouldn't be necessary.
john.mccarthy130629
Changing the workspace layout setting to another mode and then closing DW and clearing the filecache.dat file before opening it again works as long as I don't invoke the customised workspace layout that was triggering the message - which is fine.
Thanks again for your help.
