CSS Menu Writer Menu Time Limit, Bugs Out
Thread begun 1/26/2010 8:14 am by heather384148 | Last modified 1/27/2010 1:06 pm by Dani Chankhour | 2618 views | 3 replies |
heather384148
Every time I use the CSS Menu Writer it seems like I have a time limit. After a few minutes of building a menu, the CSS Menu Writer window items get rearranged and/or disappear. An unuseable scroll bar appears and the buttons at the bottom; HELP OKAY CANCEL do not work.
We can look into this further. Most likely it is some sort of memory problem that we may not be able to fix entirely.
What OS are you running? What version of DW? How much RAM do you have?
The way we would address this would probably be to add an auto-save and restore feature so that if anything happened during applicaiton you could close DW, release the memory, and then start back over from where you were instead of starting over.
I will have our QA team look into it more if you can give us more information about the machine you are running on and how many changes you are making before experiencing a problem.
heather384148
Running Vista, DW CS4, 3 GB RAM, 32-bit operang system.
Thanks!
Dani Chankhour
Have you tried renaming or deleting the cache file, this link have the step on how to do that:
146/
in addition, please make sure to have the latest version of CSSMenuWriter installed (2.0.3).
