Powerstore as digital goods
Thread begun 1/26/2010 6:19 am by tolushayoo193471 | Last modified 2/02/2010 12:46 pm by Eric Mittman | 7053 views | 18 replies |
tolushayoo193471
Please is it possible to use Powerstore as digital goods if I change few things there. I have ecart4, Digital File Pro1, Powerstore, Universal Email 2, 3.
thank you
Yes... it should just be a matter of adding a field to store the digital goods location to the products database, then adding an upload field to the products insert/update page in the admin so that you can upload the digital good associated with the product being purchased.
You would probably have to get into the code if you wanted digital goods to work with options, since a lot of the options handling is hand-coded, but if you don't need options for digital goods you can probably do it all from the insert/update server behaviors.
You would want to make sure to upload the digital goods to a folder above the site root so that people couldn't download the images without a purchase.
Then you would be able to add download links based on the digital good purchased on the receipt and/or order history pages when that product is purchased.
tolushayoo193471
thank you, but will i still need digital file pro for the customisation?
tolushayoo193471
Thank you I've followed the digital file pro manual. After I've done the insert/update on my Products_Insert.php page and I upload everything to my server. I opened Products_Insert.php thorugh my browser and I tried to insert and upload a pdf file and here is the error message that ws displayed after I clicked on submit
Fatal error: Call to undefined function
attached is my Products_Insert.php
thanks
It should work.... did you upload the file:
WA_DigitalFilePro/HelperPHP.php
the "undefined" function should be defined in that file, so it would seem that file may not have been updated based on that error. If you look in that filie can you find the wa_dfp_uploadfiles() funciton?
tolushayoo193471
Yes I uploaded the helper file and I've done it again, but it still the same error. please find the attached.
thanks
This looks like a version of WA_DigitalFilePro/HelperPHP.php from a previous version.
Maybe try deleting that file... re-run the server behavior for upload, and then upload it again. That file should be overwritten with a newer version before it will work.
tolushayoo193471
Thank you for your time. I've deleted the helper and reupload it. But I've managed to create new upload file which work perfectly, but the Products_Insert.php from the powerstore admin page which am trying to edit still pointing to line Fatal error: on line 94
but what i've also notice is is that the uploaded file is inside the targeted folder outside the root of my server, it's just the error, but the uploaded file went through. attached is the new page I've created which works and the Products_Insert.php from the powerstore admin page which am trying to edit.
thank you
Not sure what is going on.... the previous version of DFP used the function:
wa_dfp_uploadfile()
the newer version uses:
wa_dfp_uploadfiles() (notice the 's')
I can see the code on your page references the new version, but the include file is still from the old version. I'm not sure exactly what is going on, but somehow your include file is out of synch with the code on the page.
What version of DFP do you have installed?
tolushayoo193471
DFP Version, do you mean DataAssist? WADataAssist206
