Why won't the hiddenfield data insert itself into the table
Thread begun 1/26/2010 4:17 am by John Langer | Last modified 1/26/2010 4:35 pm by Eric Mittman | 2690 views | 3 replies |
John LangerBeta Tester
I use DataAssist all the time and usually have no problems but on this occasion it's beating me. Admittedly I'm customising the page a bit but some of it works and some doesn't. I know I'm missing the obvious but I just can't see it.
So, this is what it's supposed to do.
From a previous page the INSERT RECORD page is displayed but pulling an existing record using a recordset and populating that with a URL parameter from the previous page. I've tested this and all the correct information is displayed. Some fields on the insert form are pre-populated using hidden fields (getting their values from the recordset) and then these hidden fields are used to INSERT into a new record together with new information.
That all works fine apart from one hidden field that will just not insert into the new record. The offending hidden field is "origEmailID". I have attached the page and the database schema in case it's something to do with that.
What baffles me is that other hidden fields insert fine, with no bother.
So the question is; why won't the "origEmailID" insert itself into the table.
If anyone can help I'd be most grateful, many thanks.
It looks like the insert page you posted is not the page that is doing the insert for this info. The action of the form points to messaging_Insert.php. This means that the info in this form is not being used in the insert on this page.
If you can post back with that other page I can take a look to see why it might not be getting certain values to insert.
Eric, you're a star!
That was exactly it. I first of all made the normal insert page via DataAssist (messaging_Insert.php) but then made a copy of that (called it messaging_Reply.php) added a few modifications and then I got the story already related. What I didn't do was change the Action of the form to "messaging_Reply.php". Soon as I did that, it worked.
I said it was something simple that I just couldn't see. Yet again another pair of eyes does the trick.
Many thanks once again.
Always glad to be the extra set of eyes, it is all you need so often with these things.
