Cart Page Update on Press Of Update Button
Thread begun 1/26/2010 2:45 am by sales356151 | Last modified 1/27/2010 4:39 pm by Eric Mittman | 3227 views | 5 replies |
sales356151
Hi all.
Im having a small issue with a shipping module Im trying to create, its all working great using cookies and setting a session varible but here is the problem.
I have a drop menu for customer to select if they require overseas shipping in which they select the country, this sets a cookie and a session varible.
The problem is its always one step behind so it shows the previous selected item from the cart.
You will need to view this online to understand fully.
Please follow this url: product_info.php?id_prd=150
Add a item to the cart, then change the url to: view_cart2.php
Basically you will see a drop box to select the country, select a different country, it correctly changes the shipping cost but until you hit refresh the drop menu stays on the previous selected.
Hope this makes sense and someone can advise how to auto refresh this.
Kind Regards
Jamie Jackson
I was able to visit your site and see the problem. In order to make the select list default to the user selection you must set it dynamically. To do this you will need to select the dropdown in design view and in the property inspector click on the dynamic button. In here for the 'Select value equal to' option use the lightning bolt to select the variable that holds this value.
sales356151
Ive already set the value, it does hold the value but doesn't update in the drop list on first press you hae to refresh for it to show correctly.
So long as the value is set when the page loads this list should default to the value specified. Where are you setting this value on the page? If you can post back with this page in a zip archive I can take a look to see if I can spot the problem.
sales356151
Hi here is the viewcart file that this update is on, hope it makes sense.
Jamie
It looks like there might be a couple of problems on this page. The first problem I see is that you have an option outside of the select list:
<option value="" selected="selected"></option>
This should not be, options are only valid when they are in a select list. Next I can see that you are making a comparison against the $row_selected_country['ISO2'], the value comes from the recordset that is filtered by the session variable $_SESSION['shippingcountrySI'], this session variable is based on the cookie $_COOKIE["shippingcountry"].
This cookie is not set until after the session code and the recordset. To resolve this I think you will need to put this set cookie code that is on lines 137-141 up above the set session server behavior that starts on line 9. If the values are all being set correctly and the recordset is coming back with the value it should I think this will work for you.
It is really a complicated way of doing this. I think the best way to do this would be to set the cookie in the onChange event of the select list. Then just use that as the 'select value equal to' value. This should yield the result you are looking for without nearly as many steps.
