Reset Button
Thread begun 1/25/2010 12:28 pm by FARRSX4397970 | Last modified 9/15/2010 9:19 am by Jason Byrnes | 6494 views | 16 replies |
FARRSX4397970
Reset Button
Is there an easy way to add a reset button that looks like the submit image in the Contact form solutions pack. This is the text I have now.
<a href="contactus.php">Reset the Code</a>
neilo
If you want a button that just resets the form (but won't reset the captcha image):
Insert > Form > Button - and in the Properties Panel/Inspector set the action to 'Rest Form'
Make sure that the button is inside the form tags.
If you want a button to refresh your form page (so that the form resets and the captcha image changes):
Insert a button - Insert > Form > Button
In Properties Panel/Inspector, for 'Action' select 'None' - give it a value, i.e 'Reset'.
Go to Window > Behaviors and in the Behaviors Panel, click the plus sign and from the options select 'Go to URL'. Enter 'contactus.php' for the URL.
FARRSX4397970
Reset button
What if you just want captcha image to change only?
Jimmy Wu
In your contact_styled.php page, you will have to find the image code:
<img src="WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?noisecolor=<?php echo $WAGLOBAL_Captcha_Noise; ?>&bgcolor=<?php echo $WAGLOBAL_Captcha_BG; ?>&textcolor=<?php echo $WAGLOBAL_Captcha_Text; ?>&transparent=<?php echo $WAGLOBAL_Captcha_BG_transparent; ?>&characters=<?php echo $WAGLOBAL_Captcha_Characters; ?>&width=<?php echo $WAGLOBAL_Captcha_Width; ?>&height=<?php echo $WAGLOBAL_Captcha_Height; ?>&font=<?php echo $WAGLOBAL_Captcha_Font; ?>" alt="security code"/>
Add an id to it like this:
<img src="WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?noisecolor=<?php echo $WAGLOBAL_Captcha_Noise; ?>&bgcolor=<?php echo $WAGLOBAL_Captcha_BG; ?>&textcolor=<?php echo $WAGLOBAL_Captcha_Text; ?>&transparent=<?php echo $WAGLOBAL_Captcha_BG_transparent; ?>&characters=<?php echo $WAGLOBAL_Captcha_Characters; ?>&width=<?php echo $WAGLOBAL_Captcha_Width; ?>&height=<?php echo $WAGLOBAL_Captcha_Height; ?>&font=<?php echo $WAGLOBAL_Captcha_Font; ?>" alt="security code" id="captchaImage" />
Then you will have to add a script like this:
<script language="JavaScript">
function reloadImage() {
var now = new Date();
if (document) {
document.getElementById('captchaImage').src = "WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?noisecolor=" + "<?php echo $WAGLOBAL_Captcha_Noise; ?>" + "&bgcolor=" + "<?php echo $WAGLOBAL_Captcha_BG; ?>" + "&textcolor=" + "<?php echo $WAGLOBAL_Captcha_Text; ?>" + "&transparent=" + "<?php echo $WAGLOBAL_Captcha_BG_transparent; ?>" + "&characters=" + "<?php echo $WAGLOBAL_Captcha_Characters; ?>" + "&width=" + "<?php echo $WAGLOBAL_Captcha_Width; ?>" + "&height=" + "<?php echo $WAGLOBAL_Captcha_Height; ?>" + "&font=" + "<?php echo $WAGLOBAL_Captcha_Font; ?>" + "&time=" + now.getTime();
</script>
and a button that calls the reload function like this:
<input type="button" name="Button" id="button" value="Button" onclick="reloadImage()" />
FARRSX4397970
Reset button
Thankyou worked great!
phebberd116714
How do I style the image
I can get the button working following your instructions but the refreshed image I get is ugly and unreadable.
This is the code that generates my captcha image. It was created with form builder:
<img src="WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?field=captchaField&transparent=false&noisecolor=99CCCC&noiseorder=0&gridfreq=25&gridcolor=FFFF00&gridorder=0&font=Fonts/MYTYPE.TTF&characters=6&textcolor=333333" alt="Security Code" class="Captcha" id="captchaImage" />
How do I translate that into the js script.
change:
document.getElementById('captchaImage').src = "WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?noisecolor=99CCCC&bgcolor=FFFF00&textcolor=333333&transparent=false&characters=6&font=Fonts/MYTYPE.TTF&time=" + now.getTime();
elevy388997Beta Tester
Hope you can help me out here, I get the idea, but having different values than these examples is throwing me off. (just refresh the captcha image only)
<div class="fieldGroup"> <img src="WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?field=Contact_me_group_Security_code&width=140&height=50&bgcolor=000000&transparent=false&noisefreq=25&gridfreq=50&gridcolor=FFFFFF&gridorder=0&font=Fonts/MODERNA_.TTF&textcolor=990000" alt="Security Code" class="Captcha" /> </div>
you just need to add an id to the image tag:
<div class="fieldGroup"> <img  src="WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?field=Contact_me_gr oup_Security_code&width=140&height=50& bgcolor=000000&transparent=false&noisefreq =25&gridfreq=50&gridcolor=FFFFFF&grido rder=0&font=Fonts/MODERNA_.TTF&textcolor=990000" alt="Security Code" class="Captcha" id="captchaImage" /> </div>
and add the script as:
if (document) {
document.getElementById('captchaImage').src = "WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?field=Contact_me_gr oup_Security_code&width=140&height=50& bgcolor=000000&transparent=false&noisefreq =25&gridfreq=50&gridcolor=FFFFFF&grido rder=0&font=Fonts/MODERNA_.TTF&textcolor=990000";
</script>
It works except it resets the formatting on the captcha. How to change that? contact.php
