How do I get the design tap
Thread begun 1/25/2010 11:31 am by claudinevm399330 | Last modified 1/26/2010 2:51 pm by Jimmy Wu | 2751 views | 3 replies |
claudinevm399330
I'm new here with surveyor.
I got the sidemap.xml and than I created an html sidemap. I got the surveyor.css file.
How do I get to the design tap. It's not highlighted.
I understood that you are able to add your logo, copyright ..... correct?
Thanks for your help
Claudine
Jimmy Wu
I'm not sure where surveyor falls into the equation here.
What version of Sculptor are you working with?
Yes, you should be able to add logos and images to the different divs you create.
claudinevm399330
group ignited
All I created a html side map after the xml side map, and I get a file surveyor.css. I see only the code option in Dreamweaver, the Design tap is not available.
I thought I would be able to add our logo on the page and make a link to it for our site visitors. My question is: how can I this codes to a regular html page.
the version is 1.0.5
thank you
Claudine
Jimmy Wu
Just to clarify, you are using Surveyor, correct? Not Sculptor?
You posted in the Sculptor forum, but you're talking about Surveyor.
It appears you have created an HTML Site map. On the HTML Site map page, you can add images to it the same way you would add images to any other page in Dreamweaver. You would use the img tag to add images.
To get to the Design tab in Dreamweaver, you would look in the top left corner of the coding window and see the 3 buttons that say Code, Split and Design. Click on the Design or Split buttons. The split button shows part code and part design view.
