Image thumbnails not showing in cart
Thread begun 1/24/2010 12:20 pm by canonman208475 | Last modified 1/26/2010 2:46 pm by Eric Mittman | 3175 views | 4 replies |
canonman208475
I am using eCart 4. I got to page 50 in "Getting Started Guide" and tested my work so far. I openned the Music and Gear pages and added items to my "Cart" everything works except the Thumbnails do not show up.
I check the code and everyting looks ok, but no images I can't figure out why.
Please help
Here's the code
<img src="images/thumbs/<?php echo $BlueSkyCart->DisplayInfo['Thumbnail']; ?>" alt="" width="99" height="97" class="eC_ProductThumb" />
Is the thumbnail name being stored by the add to cart button?
double check the Add to cart button settings, make sure that the thumbnail cart column is properly bound to the database thumbnail column.
canonman208475
the button settings look good
Where would I look in the cart code to find "thumbnail cart column" and check connection?
canonman208475
here is code for Repeat Cart Region
I hope this helps but it looks like correct to me..I might be missing something tho.
while (!$BlueSkyCart->EOF()) {
<tr>
<td><img src="images/thumbs/<?php echo $BlueSkyCart->DisplayInfo['Thumbnail']; ?>" alt="" width="99" height="97" class="eC_ProductThumb" />
<p class="eC_ItemLabel">&nbsp;</p></td>
<td class="eC_PriceItem" >&nbsp;</td>
<td class="eC_FormItem" ><input type="text" name="BlueSkyCart_Quantity_<?php echo $BlueSkyCart->DisplayIndex; ?>" size="3" value="<?php echo $BlueSkyCart->DisplayInfo("Quantity"); ?>" /></td>
<td class="eC_FormItem" ><input type="checkbox" value="<?php echo $BlueSkyCart->DisplayInfo("ID"); ?>" name="BlueSkyCart_Delete_<?php echo $BlueSkyCart->DisplayIndex; ?>" /></td>
</tr>
$BlueSkyCart->MoveNext();
$BlueSkyCart->MoveFirst();
On this page you will need to edit the add to cart server behavior. In here you will need to look at the thum nail column and make sure to bind it to the recordset value for the thumbnail. When you associate the thumbnail like this you should then have the value present in the cart. If you have any further trouble with this post back with a copy of your page that has the add to cart on it and any other details about the recordset and the column that holds the thumbnail.
