Adding HTML Editor to an existing form
Thread begun 1/22/2010 1:55 pm by nickj | Last modified 1/25/2010 2:32 pm by Jimmy Wu | 2062 views | 3 replies |
nickj
When adding the editor to an existing form, the input field name is replace by something but then I need to update the input/update forms to bind this new thingy:) . What do I bind to? This form was not built by WADA it was built with ADDT.
nick
Jimmy Wu
Could you go into more detail on what you are trying to do? I'm not entirely sure that I understand what you are asking about.
nickj
I have an existing form, built last year with ADDT and I want to replace an existin text input with the HTML Editor .
Since the editor replaces the form input: ( <input type="text" name="summary_<?php echo $cnt1; ?>" id="summary_<?php echo $cnt1; ?>" value="<?php echo KT_escapeAttribute($row_rsevent_eve['summary']); ?>" size="32" maxlength="255" />
with it's own reference, how do I update the insert behavior, what do I bind that field in the database with?
Nick
Jimmy Wu
The HTML editor instance should have the same name as the text field that was in your original form. You should bind the value to the same field.
