Connect ecart to First Data
Thread begun 1/22/2010 10:08 am by info398618 | Last modified 1/25/2010 12:44 pm by Eric Mittman | 1607 views | 1 replies |
info398618
Hi..I need to know what what all I need to do to link ecart to First Data? During the checkout wizard process, I already put in the customerid the wizard asked for and I see that linkpoint_required, linkpoint_itemized and linkpoint_optional APIs have been created in the code. But the cart isnt working. When I hit submit on the confirm.php page after putting in credit card info, it goes nowhere and I get a "cannot display page" from the browser. What do I need? Thanks.
Are you just trying to use a standard linkpoint checkout within the cart? I'm not sure about the first data portion of this but I know that Linkpoint is supported and you should be able to craft the checkout with the checkout wizard. Let us know if you have tried to customize the checkout after it has been created.
When you get the page cannot be displayed you should right click on the page and try to view the source to see if it has some xml that it is trying to post back. You may need to test this out in a different browser to see more about the problem.
