SQL connection not working
Thread begun 1/21/2010 10:03 pm by victor367017 | Last modified 1/22/2010 11:09 am by Jason Byrnes | 1541 views | 1 replies |
victor367017
I have got to be doing something wrong. I have and ODBC connection defined on my local machine and on my web server that are the sme - pointing to my SQL database on the server. When I create a page with DW to access the data I can do it if I use NATIVE DW record set. I create a page am I see a single record.
I what to see more that one recored so I turn to DataAssist. I go through the process of creating the "result page" and on my local machine I see all the fields. I go to publish it to the web (using the same connection string that worked in native DW mode) and I get the error that
The Website cannot display the page
Most likely cause :
Website is under maintenace
Website has a programming error
When I look at the record set that data assist generated I see an ERROR Incorrect Syntax Near the keyword "Order" which is the first field in the view that I am connecting to?
What am I doing wrong????
Order is a reserved word in MySQL and should be avoided as a column name.
For a full list of reserved words see the following:
reserved-words.html
