authorize.net gateway settings
Thread begun 1/21/2010 8:07 pm by jack279078 | Last modified 2/01/2010 1:33 pm by jack279078 | 4714 views | 6 replies |
jack279078
I have decided not to ust pay pal and instead have authorize.net. After recieiving my login and key They were entered into WA_Globals.and nothing. In the test mode I was able to complete a nonexisitant transaction. NowI link staraight to checkout Failure. I don,t think I am making it to authorize.nets sandbox. Here is the code (less the actual login infromation)
/* Payment Settings
* Use this key to determine the appropriate value for the $WAGLOBAL_Gateway setting:
* PayPal = 1
* Authorize.net = 2
$WAGLOBAL_Gateway = "2"; //Enter the appropriate value based on the above key. PayPal is specified by default.
$WAGLOBAL_Test_Mode = false; //Set to true if you are testing your shopping cart and do not want to send information to your payment gateway.
//Only complete the payment gateway options for the gateway you have selected to use in the $WAGLOBAL_Gateway setting.
//PayPal Settings
$WAGLOBAL_Paypal_Sandbox = "false"; //Set to true if you wish to use the PayPal Sandbox for testing transactions.
$WAGLOBAL_Paypal_User = "";
$WAGLOBAL_Paypal_Password = "";
$WAGLOBAL_Paypal_Signature = "";
//Authorize.net Settings
$WAGLOBAL_Authnet_Sandbox = "TRUE"; //Set to true if you wish to use the Authorize.net Sandbox for testing transactions.
$WAGLOBAL_Authnet_login = "XXXXXXXXXX";
$WAGLOBAL_Authnet_tran_key = "XXXXXXXXXXXXXX";
As always any help will be greatly appreciated.
jack
Dani Chankhour
Try changing the post url to the test server. In WA_eCart/Adv_CO_Scripts folder open the AuthNet_PHP.php file and try changing this url:
transact.dll
to
transact.dll
remember to change it back to secure when you are done with testing.
jack279078
This seemed to have no noticeable effect. Does the Pay pal button and code have to manually be removed and could this be a factor with my problem seems that seems the papal option is still there it might be interfering with authorize.net.
jack
In order to determine what may be wrong with your Authorize.NET checkout you will need to add in the full request and full response to your checkout failure page. Here is the code to add to this page:
<br />The Authorize.net full requst is: <?php echo(AuthNet_Result("Full Request")) ?><br />
<br />
The Authorize.net full response is: <?php echo(AuthNet_Result("Full Response")) ?><br />
Put your cursor on the page where you would like to see this information, then go into split view and paste the code in. When you test the Authorize.NET checkout you should see the full request and full response here. If you have trouble understanding the error please post back with this.
jack279078
I'm just getting back to this problem. Here is ths error response
Fatal error: Call to undefined function AuthNet_Result() in /home/content/n/h/j/nhjac/html/outdoor/checkout_failure.php on line 143
that seems to be refering to the error code request. I'm stuck
jack
Looks like there is no include for the Authnet function, you will need to add this to the top of your page:
require_once("WA_eCart/Adv_CO_Scripts/AuthNet_PHP.php");
Add this in and test it again, you should see some detailed info about the request and response from the API. Please post back with what you discover.
jack279078
re:
I had to set all test modes to false in order to have the transaction forwarded to the appropriate authorize.net server. I am still in test mode with authorize.net and am able to sumit tranactions without the card being charged. According to the techs at authorize,net the cart settings will be the same, for live or test mode, and will be set at there end. Here is what I have at coded in the WA-Globals.php It is working and all is good in the world.
$WAGLOBAL_Test_Mode = "false"; //Set to true if you are testing your shopping cart and do not want to send information to your payment gateway.
//PayPal Settings
$WAGLOBAL_Authnet_Sandbox = "false"; //Set to true if you wish to use the Authorize.net Sandbox for testing transactions.
jack
