Cookies Toolkit Not Restoring HTML-Editor Field
Thread begun 1/21/2010 9:26 am by Sailors | Last modified 1/15/2012 5:55 pm by Ray Borduin | 6344 views | 5 replies |
Sailors
Hi All,
I have a multi-page form where Form A (on Page One) contains an HTML Editor field. I stored the entire form in cookies and set the onload event to restore entire form. But when I click the back button from Page Two, some text fields on Form A are not restored and as well as the field that contains the HTML-Editor. Meanwhile all the form fields are passed to Page Two.
Any ideas as to what could be the cause of the problem.
Thanks.
I have done some testing on this and can confirm that HTML Editor values do not get set properly when coming from a cookie. I have logged a bug for this but I was not able to find a way to get the cookies to work with the HTML Editor instance.
As a workaround I was able to store the HTML Editor value in a session variable, then I set the initial value of the editor to this session variable. This seemed to work out ok.
On the page that the form is posting to you would add in a piece of code to the top of the page like this:
<?php if(!session_id()) session_start();
if(isset(
$_POST['test'])){
$_SESSION['test_val'] = $_POST['test'];
Then in your HTML Editor instance use this as the initial value code:
<?php echo ((isset($_SESSION["test_val"]))?$_SESSION["test_val"]:""); ?>
You will need to update the word 'test' in these code examples with the name of your editor. If you have any problem with this let us know and post back with the pages in question and we can show you how to add this.
Sailors
if(isset(
$_POST['test'])){
Hi Eric,
Thanks for the reply. Another issue I'm having with this is when I click the back button the value stored in the session gets restored in the editor. But when there's a space at the beginning of the value stored in the session the editor doesn't convert it back to space but puts the mark-up #&160 ; at the beginning. Is there a way to overcome this issue?
You may want to try using html_entity_decode() around the initial value like this:
<?php echo ((isset($_SESSION["test_val"]))?html_entity_decode($_SESSION["test_val"]):""); ?>
This should convert the values for you that can be decoded.
Cologne
is there a solution for the cookies toolkid?
Please post a copy of the page where you are having the issue and we can suggest how to fix it.
