Fatal error: Uncaught Error: Call undefined function mysql_pconnect() /home/mabr827uwtip/public_html/Connections/PowerStoreConnection php:9 Stack trace: #0 /home/mabr827uwtip/public_html/webassist/themes/theme_open php(24): require_once() #1 /home/ma
Thread begun 4/05/2026 5:06 am by Dan808 | Last modified 4/07/2026 4:11 am by Mags | 329 views | 1 replies |
Dan808
Fatal error: Uncaught Error: Call undefined function mysql_pconnect() /home/mabr827uwtip/public_html/Connections/PowerStoreConnection php:9 Stack trace: #0 /home/mabr827uwtip/public_html/webassist/themes/theme_open php(24): require_once() #1 /home/mabr827u
Hello, WebAssist, The website wheezingeezer.com was live for "15 years" with no issues whatsoever, then the client had credit card issues and did not pay hosting fees on time so the website went down. Once this was realized and hosting was started up again... I uploaded a backup of PowerStore and now this error is occurring. GoDaddy told me to open the website in a (Firefox Private Window) which shows the exact error. I also saw in a different post in your forums a similar problem which turned out to be the version of PHP on the server. They were told to downgrade to version 7? I am currently seeing version 8.3 on my economy hosting plan. I'm have a strong feeling... Could you please give me some direction on how to correct this? WheezinGeezer is lost and needs to find his way home. Thank You WebAssist for an AWESOME STORE! 15 YEARS WITH NO ISSUES! -- Best Regards, Daniel Shantz.
Complete Error reads as follows -- Fatal error: Uncaught Error: Call to undefined function mysql_pconnect() in /home/mabr827uwtip/public_html/Connections/PowerStoreConnection.php:9 Stack trace: #0 /home/mabr827uwtip/public_html/webassist/themes/theme_open.php(24): require_once() #1 /home/mabr827uwtip/public_html/index.php(3): require_once('/home/mabr827uw...') #2 {main} thrown in /home/mabr827uwtip/public_html/Connections/PowerStoreConnection.php on line 9
-- end --
Cheers!
Mags
Hi Daniel, not sure if you're aware, but Ray sadly passed away in 2023 and there is no new development being done on the WebAssist code. The forums are now running peer-to-peer help only. The error message means you're running old mySQL code, which was deprecated in PHP 5.3 and removed completely in PHP7, so it will not run on PHP8.3. If you can roll back to an older PHP version that supports mySQL, it would run however it's definitely not advisable as older versions aren't supported and are also a big security risk. The correct thing to do is update your code to mySQLi - you can do this using the free mySQLi extension available on this site. It will first update your Connections file but you will then need to open every page which currently uses mySQL server behaviors, double-click every recordset and server behavior i.e. Insert, Update, Delete etc, then click OK and the code will be updated for you. You need to do this on every page and check the pages as you go to make sure they work and if not, turn on error reporting so you can see what the issue is. It's time consuming but it works!
