Dynamic displays for eCart
Thread begun 1/21/2010 6:59 am by fdotmedia | Last modified 1/22/2010 10:16 am by Jason Byrnes | 3432 views | 7 replies |
fdotmedia
I've made an eCart page and want to see if I can show DB values based on whether it exists or not...
example:
id   name   address   email          sex
1 bob 123 s st bob@b.com M
2 kim 123 s st kim@k.com NULL
I want to return something that looks like this in the recordset...
Bob - M - 123 s st - bob@b.com
Kim - 123 s st - kim@k.com
Can I do that with eCart?
Thanks,
Ted
This is not a function of eCart, you need to add an if statement around the display for the sex column:
<?php if($row_RecordSetName['ColumnName'] != NULL || $row_RecordSetName['ColumnName'] != "") { ?>
echo $row_RecordSetName['ColumnName']; ?>
fdotmedia
so I'd need to have the same code you graciously added to each of the four fields? changing only the recordset row?
yes, that is correct.
fdotmedia
works like a charm thank you...
I have run into a different problem though...
I'm adding the "add to cart" button as a recordset and when you click on the 2nd button the script redirects to the same page and empties the recordset... It's eCart_2_ID_Add I'm not getting anything from eCart_1_ID_Add works as expected...
// WA eCart AddToCart
if (isset($_POST["eCart1_2_ATC"]) || isset($_POST["eCart1_2_ATC_x"])) {
$ATC_itemID = $_POST["eCart1_2_ID_Add"];
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "";
$ATC_RedirectIfIn = "";
if (isset($totalRows_products) && $totalRows_products > 0) {
$row_products = WAEC_findRecordMySQL($products, "Pid", $ATC_itemID);
if ($row_products) {
$ATC_itemName = "".$row_products['PFGtitle'] ."";// column binding
$ATC_itemDescription = "";// column binding
$ATC_itemWeight = floatval("0");// column binding
$ATC_itemQuantity = "".$_POST["eCart1_2_Quantity_Add"] ."";// column binding
$ATC_itemPrice = floatval("".$row_products['PFGprice'] ."");// column binding
mysql_data_seek($products, 0);
$row_products = mysql_fetch_assoc($products);
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$eCart1->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice);
if ($ATC_RedirectAfter != "" && $eCart1->redirStr == "") {
$eCart1->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
// WA eCart Redirect
if ($eCart1->redirStr != "") {
header("Location: ".$eCart1->redirStr);
<?php if($row_products['PFGid'] != "" || $row_products['PFGid'] != "") { ?>
<p> <span style="color:#000; font-weight:bold; font-size:11px;"><?php echo $row_products['PFGid']; ?> - <?php echo $row_products['PFGtitle']; ?> - <?php echo $row_products['PFGprice']; ?></span>
<form name="eCart1_2_ATC_<?php echo $row_products['PFGid']; ?>" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>">
<input type="hidden" name="eCart1_2_ID_Add" value="<?php echo $row_products['PFGid']; ?>" >
<input type="text" name="eCart1_2_Quantity_Add" value="1" size="4" >
<input type="submit" value="Add to Cart" name="eCart1_2_ATC">
</form>
</p><?php } ?>
How iis the recordset filtered?
Can you send a copy of your page so I can see the code in context?
Top send a php page, compress it into a zip archive and attach the zip file to your reply.
fdotmedia
There's the attachment... Thanks Jason!
In the first add to cart button which works, you are binding the ID cart column to the Pid recordset column, in the second one you are binding to the PFGid, Why not the Pid Column?
