Filling a field#2 based on select field#1
Thread begun 12/20/2025 11:20 am by birdscreen398247 | Last modified 7/10/2026 3:45 am by anonymous | 322 views | 5 replies |
birdscreen398247
I have a Select field on a form that uses a recordset.
When I select that field, I would like another field on the form to be automatically filled in from data in that recordset (or another recordset filtered on the data from that select field).
I know it involves onchange and a script, but I can't figure out the script to use.
Any suggestions?
Mags
Can you email me at mwilson@linksdesign.co.uk and I'll send you a solution? For some reason I can't post my answer here, keep getting a Forbidden message!
PatriceWebAssist
Mags: Is this the same issue as a few months ago? If I recall it was a timing problem.
Mags
It seems to be related to the content of the message as I was trying to paste in some code which didn't let me post, but I was able to reply with the text message above. Just tried again and got the same Forbidden error. Then I tried pasting the code into the PM section - same problem.
PatriceWebAssist
very odd... Let me know if you see any common issues so we can further troubleshoot.
If you have time, let's coordinate a time to run some tests.
anonymous
American Airlines Name Change Number
American Airlines Name Change Number+1(877)321-1260
copa airlines name change number +1(877)321-1260
Delta Airlines name change Number +1(877)321-1260
JetBlue Airways Name Change Number +1(877)321-1260
https://www.instagram.com/p/DamcxiRt__S/ +1(877)321-1260
https://www.instagram.com/p/DamdW4wtO4s/ +1(877)321-1260
https://www.instagram.com/p/Damd-FltwtS/ +1(877)321-1260
https://www.instagram.com/p/DamewfZtmx2/ +1(877)321-1260
<p>
<a href="https://rumble.com/shorts/v7c6frg">American Airlines Name Change policy</a><p>
<a href="https://www.instagram.com/p/DaSZUW7EXf1/">Air europa date of birth change policy</a><p>
<a href="https://www.instagram.com/p/DaSY7JtEXbe/">uzbekistan airways date of birth change policy</a><p>
<a href="https://www.instagram.com/p/DaSWzTrkepC/">czech airways date of birth change policy</a><p>
<a href="https://www.instagram.com/p/DaSWd8GkaNr/">vueling date of birth change policy</a><p>
