' in Subject Line
Thread begun 7/28/2025 8:22 am by BillHobbs | Last modified 8/08/2025 8:32 am by BillHobbs | 282 views | 2 replies |
BillHobbs
' in Subject Line
I have an upload form that sends an email to the uploader when their files are uploaded. I give the client the opportunity to name the group of files. That name is used by the email form to sent the client an email where the subject line is named Project: (Client's Data). My problem is that when the client enters an apostrophe it gets changed to ' instead of an apostrophe. Example: if the client entered "My Project's Files" then the email will have in the subject line "Project: My Project's Files". Any idea how I can fix this?
Mags
Hi Bill, I had a similar issue a couple of weeks ago with a recordset value being pulled into a hidden field on a form. What you're seeing is the HTML entity encoding for an apostrophe. In my case, I was able to make it work properly by decoding the HTML entity before output, like this:
<?php echo html_entity_decode($rsUserInfo->getColumnVal("display_name")); ?>
Hope you can adjust this to suit your requirements but if you need a hand, feel free to post the HTML code for your form and I'll take a look.
BillHobbs
Thanks, I'll try that.
