WA errors from fresh product manager install
Thread begun 4/23/2025 4:09 pm by Peterson Design Studio - jefferis | Last modified 4/25/2025 5:42 pm by Jay Core Global Media | 773 views | 4 replies |
So, I am trying to install product update pages from scratch. I've created the pages, but I'm finding errors with a fresh install.
I have the latest version of data bridge
error: Parse error: syntax error, unexpected token ")", expecting variable or "{" or "$" in /usr/home/name/public_html/cartierbuyer.com/AdminNew/admin/products_results.php on line 26
Line 26 is: $DeleteQuery = new WA_MySQLi_Query($);
Any suggestions?
Also, line 50 appears to have an error:
$WADAProducts = new WA_MySQLi_RS("WADAProducts",$,10); but i can't get to that one until line 26 is fixed.
error
That error usually means there's a misplaced or extra closing parenthesis ) in your PHP code, often right after a function declaration or in an unexpected spot. PHP is telling you:
You're passing just a dollar sign $ as the argument. PHP is expecting a variable name after the dollar sign (like $myconn, $conn, etc.), but instead you gave it an incomplete variable. so replace $ with your msqli connection variable
please attach page or full delete query or record set so th community can try to pin point the problem. Hope this helps
attachments aren't working
All i get is a white screen when I try to attach the file I am sending a link : https://drive.google.com/file/d/1X0HKvnYuEFAiJu46P2sXd8313bDsXDQA/view?usp=sharing
what is weird
this error was produced by the default wizard for product pages
for some reason on the 5th try, the attachment uploaded
error
sometime it is a little buggy the wizard. So first would be for you to define a mysql connection file if you have not done so,On line 3 <?php require_once('../../Connections/.php'); ?> the connection file is just .php so the page has no connection to your database. whatever the name of your connect file is for example connectdatabase.php the dataassist pages will use that file name for the delete, insert etc functions. So line 26 looks like this
if your connection file was named connectdatabase.php then line 26 would look like
$DeleteQuery = new WA_MySQLi_Query($connectdatabase);
