deprecated functions?
Thread begun 4/18/2025 3:05 pm by Peterson Design Studio - jefferis | Last modified 4/21/2025 6:02 pm by Peterson Design Studio - jefferis | 1990 views | 10 replies |
How do i correct this error? THANKS
Deprecated: Creation of dynamic property WA_MySQLi_RS::$Columns is deprecated in /usr/home/bendannie/public_html/tiffanybuyer.com/webassist/mysqli/rsobj.php on line 5
GETTING THESE ERRORS ON MSQLi
Deprecated: Creation of dynamic property WA_MySQLi_RS::$Connection is deprecated in /usr/home/bendannie/public_html/tiffanybuyer.com/webassist/mysqli/rsobj.php on line 6
Deprecated: Creation of dynamic property WA_MySQLi_RS::$CurrentPage is deprecated in /usr/home/bendannie/public_html/tiffanybuyer.com/webassist/mysqli/rsobj.php on line 7
Deprecated: Creation of dynamic property WA_MySQLi_RS::$CrossSiteProtect is deprecated in /usr/home/bendannie/public_html/tiffanybuyer.com/webassist/mysqli/rsobj.php on line 8
these are lines from the rsobj
class WA_MySQLi_RS {
public function __construct($name,$conn,$maxRows=0,$skipRows=0) {
$this->Columns = array();
$this->Connection = $conn;
$this->CurrentPage = $_SERVER['REQUEST_URI'];
$this->CrossSiteProtect = true;
$this->Debug = false;
$this->EncryptionAlgorithm = "blowfish";
$this->EncryptionKey = "Change Me";
$this->EncryptionMode = "cbc";
Mags
Which version of rsobj.php are you using? It should have a version no. in the first line of the file.
thanks
// version 2.35 funny, not getting notifications of replies...
Jay Core Global Media
rsobj.php
Ive attached version 2.55. Also what php version are you using
Mags
The email notifications stopped working a while back, sadly! I see Jay Core Global Media has supplied the most up-to-date rsobj.php file, that's the one I use on PHP8.2 so should hopefully solve the issue. Usually deprecation warnings can be ignored and won't stop things from working as they should, but they will cause issues in future versions of PHP. At some point our dwindling band of WA users will have to move to a different system unfortunately, particularly as Dreamweaver is also no longer being updated other than bug fixes etc.
thanks
it was causing pages not to load thank you. Do I need to run connection scripts in WA again or just replace the file?
Replace file
You should just be able to replace the file i uploaded
Alternatives
Originally Said By: Mags
So the only one close to DW I've seen is the DMX Zone system Wappler. It seems to have some database plugins and functions, I just don't know how robust it is compared to WA. I recently lost most compatibility with my Project VII plugins :-( And the business is now closed . So sad, PVII plugins (and WA) were the best but my main reason for keeping active subscriptions with DW. I guess in August when my next renewal is due, I will say so long and farewell :-( When Macromedia sold out to Adobe, and they stopped using Fireworks, I knew the end was coming, especially when I was on the beta tester team for DW and all the development was turned over to India and the developers did not listen to any of our suggestions.
recreating login and rsobj ?
Thank you all for the updated rsobj file! That helped. Now I am trying to update an administrative backend connection My question is if I redo the security login for the admin area, will it overwrite the rsobj file with the outdated one? Or any other problems I might run into with a recreate? I think the system I used initially was an old Adobe KT system rather than WA
If you download WA data assist and reinstall it (it is now free) should have an updated rsobj.php you can create a connection file. I think I use Dmx zone extension manager to install web assist extensions.
