storing entire form in cookie for 1 day not clearing itself
Thread begun 1/20/2010 1:14 pm by neileisen207079 | Last modified 2/01/2010 6:19 pm by Eric Mittman | 4384 views | 6 replies |
neileisen207079
I have the store entire form in cookie behavior working and it works fine. I have it set to save for 1 day. The only problem is a week later all the info is still there. I did a work around by having the cookie cleared on the load of the home page, but it should work, right?
Also I would rather have it cleared when the browser is closed.
This is the form submit code:
<form action="confirmquote.php" method="post" enctype="multipart/form-data" name="specialorder" id="specialorder" onsubmit="WA_setFormCookie(WA_CookieObj,document.specialorder,'WAFC_details_specialorder', 1);WA_setCookie(WA_CookieObj,'instructions',document.specialorder.instructions.value,true,0,1)">
This is in the head:
function WA_setCookie(cookieobj, cookiename, cookievalue, cookiecheck, settype, expdays) {
var theValue = "";
if (settype == 1) {
for (var n=0; n<cookievalue.length; n++) {
if (cookievalue[n].checked) {
theValue = cookievalue[n].value;
else if (settype == 2) {
for (var n=0; n<cookievalue.options.length; n++) {
if (cookievalue.options[n].selected) {
if (theValue != "")
theValue += ", ";
theValue += cookievalue.options[n].value;
else {
if (cookiecheck) {
if (expdays) {
cookieobj.expires = daysToExpire(expdays);
else {
cookieobj.expires = "";
cookieobj.setValue(cookiename, theValue, expdays);
</script>
Looking at the code you have to set the cookie it seems that it should be set to expire in one day. You can check this out by viewing the cookie in FireFox. You do this by going to Tools > Options > Privacy > remove individual cookies.
In here find the domain your cookie is coming from and locate the cookie. When you select the cookie you should be able to see all of it's attributes including the expiration date.
If you would like the cookie to end with the session you should try leaving the expiration days blank. If there is no value specified it should exist only during the session. Please post back and let us know what you discover.
neileisen207079
Still not working
OK, I checked in Firefox and in Safari and both show the same thing. Even though the code is set to expire in 1 day ( it shows the numer 1 in the code) it sets itself for 1 month.
I tried leaving it blank, and it stopped working. I tried making it 0 and it still set it for 1 month.
neileisen207079
PS
I also added it to a totally different form on a different page and it also does the same thing. No matter what I put it expires in a month.
Can you post back with your new sample test page that is also expiring in a month. When I'm testing this out the cookie is set to expire the next day when I set it to 1. It does not seem to matter what browser I'm using. I would like to do some testing with your cookie if I can.
neileisen207079
Simple form set to 1 day still expires in 30
I decided to make a test form with one field and set the cookie to expire in 1 day. I tried it today, January 30th and the cookie it set in Firefox shows it expires on March 1, which is 30 days from now.
Whats wrong?
Thanks.... file attached.
What is the version of Cookies Toolkit that you are working with? It seems that you have an older versions code on the page that is not taking into account the expiration days. You should update the function on this page on lines 7-13 with this:
function WA_setFormCookie(cookieObj, formObj, cookieName, expdays) {
if (expdays) {
cookieObj.expires = daysToExpire(expdays);
else {
cookieObj.expires = "";
cookieFormToString(cookieObj,formObj,cookieName);
</script>
This should not be an issue in the latest release of the cookies toolkit which is 3.1.2 at the time of this post.
