Estimate Shipping from View Cart Page
Thread begun 1/20/2010 12:26 pm by ryanteets270615 | Last modified 1/20/2010 1:45 pm by ryanteets270615 | 2696 views | 2 replies |
ryanteets270615
I have a simple form on the View Cart page to get the UPSP shipping estimate. The Form submits to getshipquote.php page that takes the entered zipcode and looks up the cost. The problem is that the quote page does not return back to the $Shipping_SuccessURL once it retrieves the estimate. It does however get the correct estimate and if something other than a zipcode is entered it does redirect to the $Shipping_FailureURL.
Is there something I'm missing here? Thanks!
View_cart.php form:
<form action="getshipquote.php" method="post" name="GetShipping">
<label>Destination Zip code: </label><input name="shipping_postcode" type="text" id="shipping_postcode" size="15" />
<input type="submit" name="button" id="button" value="Apply" /></form>
getshipquote.php code:
//WA eCart Include
require_once("../WA_eCart/ecoCart_PHP.php");
$ecoCart->GetContent();
//WA eCart UPS Shipping Include
require_once("../WA_eCart/WA_eCart_USPS_PHP.php");
if ("" == "") {
//WA eCart (Copyright 2007, WebAssist)
//WA eCart USPS Shipping - USPS
$Shipping_SuccessURL = "view_cart.php";
$Shipping_FailureURL = "shipping_failure.php";
$Shipping_Packaging = 0;
$Shipping_PackageArray = array();
$Shipping_PackageIndex = 0;
$Shipping_Counter = 0;
$Shipping_Parameters = array();
$Shipping_Parameters["ShiptoZip"] = "".((isset($_POST["shipping_postcode"]))?$_POST["shipping_postcode"]:"") ."";
$Shipping_Parameters["ShiptoCountry"] = "United States";
$Shipping_Parameters["UserID"] = "60##########";
$Shipping_Parameters["USPSServer"] = "http://production.shippingapis.com/shippingapi.dll";
$Shipping_Parameters["CarrierCode"] = "FIRST CLASS";
$Shipping_Parameters["DefaultIntl"] = "none";
$Shipping_Parameters["ShipperZip"] = "90069";
while (($Shipping_Packaging == 1 && !$ecoCart->EOF()) || ($Shipping_Packaging == 0 && $Shipping_Counter == 0)) {
if (WA_eCart_USPS_IsTrueValue("true")) {
$Shipping_PackageArray[] = array();
$Shipping_PackageIndex = sizeof($Shipping_PackageArray)-1;
$Shipping_PackageArray[$Shipping_PackageIndex]["eCart_Quantity"] = (($Shipping_Packaging == 1)?$ecoCart->DisplayInfo("Quantity"):1);
$Shipping_PackageArray[$Shipping_PackageIndex]["IsPackage"] = "true";
$Shipping_PackageArray[$Shipping_PackageIndex]["Quantity"] = "1";
$Shipping_PackageArray[$Shipping_PackageIndex]["WeightUnits"] = "oz";
/* Replaced these with above entries
$Shipping_PackageArray[$Shipping_PackageIndex]["Quantity"] = "".WA_eCart_FormatNumber($ecoCart->DisplayInfo('Quantity'), true, 1) ."";
$Shipping_PackageArray[$Shipping_PackageIndex]["WeightUnits"] = "".strtolower($ecoCart->WeightUnits) ."";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageWeight"] = "".WA_eCart_FormatNumber($ecoCart->TotalColumn('TotalWeight'), true, 1) ."";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageType"] = "YOURPACKAGING";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageSize"] = "REGULAR";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageMachinable"] = "false";
$Shipping_PackageArray[$Shipping_PackageIndex]["IPackageType"] = "none";
//Special Services
$Shipping_Counter++;
if ($Shipping_Packaging == 1) $ecoCart->MoveNext();
if ($Shipping_Packaging == 1) $ecoCart->MoveFirst();
$Shipping_Result = WA_eCart_USPS_GetRateQuote($ecoCart, $Shipping_Parameters, $Shipping_PackageArray);
if ($Shipping_Result && $Shipping_SuccessURL != "")
$ecoCart->redirStr = $Shipping_SuccessURL;
else if (!$Shipping_Result && $Shipping_FailureURL != "") {
Header("Location: " . $Shipping_FailureURL); exit;
else if (!isset($_SESSION["ecoCart_USPS_Success"])) {
WA_eCart_USPS_SetSessionDefaults($ecoCart);
make sure you have the following code just before the doctype tag.
// WA eCart Redirect
if ($ecoCart_PHP->redirStr != "")     {
header("Location: ".$ecoCart_PHP->redirStr);
if it still doesn't work, there may be a php error occuring, add the following at line 1 to turn error reporting on:
error_reporting
(E_ALL);
ryanteets270615
this worked
not sure why, but your suggestion did not work either. But I was able to figure this out:
if ($_SESSION["ecoCart_USPS_Success"] != "") {
header("Location: ".$Shipping_SuccessURL);
Thank you!!
