Power CMS
Thread begun 1/20/2010 11:50 am by christine310921 | Last modified 1/20/2010 4:58 pm by shadow329043 | 2687 views | 6 replies |
christine310921
Power CMS
I have uploaded my files to my website and when I login to the admin it says no database selected. I have configured the localhost.php in Dreamweaver and it connects okay. I have also set up the database in PHPMyAdmin on my host. Can someone tell me why I am getting this message.
shadow329043
Did you do the sql import to set up the database? - it is in the database folder. Here are the instructions importing_sql.pdf
christine310921
No database selected
I have configured the localhost.php as instructed. Tested it in Dreamweaver and it is okay. I have PHPMyAdmin on my local host and imported the SQL file into a database I created using the same database name. I then set up a User and Password identical on the remote host. Any other ideas?
neilo
"I then set up a User and Password identical on the remote host."
If you began ny setting up the database on your local computer, I don't understand how you can then set up a user and password 'identical' on your remote server?
Did you use your remote hosting username and password when you installed mysql on your machine? I use IIS - so I'm unfamiliar with how other server models are configured for testing purposes.
It is often the case that your mysql login and username is partially set from (prefixed by) your Hosting account username.
so my local connection is
$hostname_mymachine = "localhost";
$database_mymachine = "cms";
$username_mymachine = "root";
$password_mymachine = "XXXXXXXX";
whereas my hosted mysql is
$hostname_localhost = "www.pictuality.co.uk"; (or localhost)
$database_localhost = "uks6XXX6cms";
$username_localhost = "uks6XXX6nh";
$password_localhost = "XXXXXXXX";
[uks6XXX6 being my host-assigned prefix]
shadow329043
I am familar with both IIS and MySQL and you have to set up a database user and password on a remote data table before you can access it........and it is that information that you put into the localhost file.....while you are on your remote data table, you should import the sql file and create the necessary data structure.
christine310921
Everything is working now
Hi everyone,
Thanks for all your input. I understood what you posted but had done everything as you had described. Because of this I thought I would just delete the database on the remote server and re-install it with the same settings. This time it worked!!!
Thanks for all your help.
shadow329043
glad to hear it - it is always best just to delete and reinstall
Shadow
