2 update server behaviors on 1 page??
Thread begun 1/20/2010 11:28 am by troyd | Last modified 1/22/2010 5:51 pm by Eric Mittman | 2757 views | 6 replies |
troyd
I'm reading in other threads that this is ok to do. And I have all the other pages (Results, Details, Delete, Insert), working fine so far. But with the Update page, I've ran into some difficulties.
First, when performing an update using the original update form, it updates with success. So my second update form doesn't seem to be killing the first form.
But when I click "Update" on the record for the second table and then try to update that record, it does nothing. Well, it goes to the Details page but without any update being performed to the table. And I also noticed that the URL is missing the actual ID. It just has ?id= after the url when using the second form.
I have this page set using 2 show if statements. One for each form. This is working great. If the "Update" button for the record for form 1 is clicked, then it fills in the form and the second form is hidden. And vise-versa.
The record value and redirect for the first form is
$WA_redirectURL = "tblMyrecords_Detail.php?id=".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"")  ."";
$WA_where_fieldValuesStr = "".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"")  ."";
What should it be for the second update form? Do I need to change WADAUpdateRecordID to WADAUpdateRecordID2?
Both tables use "id" as the key column. So it seems I have a session conflict, maybe?
The recordsets WHERE statement is as follows,
SELECT *
FROM tblMyFirstTable
WHERE id = colname
SELECT *
FROM tblMySecondTable
WHERE id = colname
Thanks in advance,
TroyD
troyd
By the way, here is my sql for both record sets.
<?php $Paramid_rsTable1 = "-1";
if (isset(
$_GET['id'])) {
$Paramid_rsTable1 = (get_magic_quotes_gpc()) ? $_GET['id'] : addslashes($_GET['id']);
mysql_select_db($database_dbCMS, $dbCMS);
$query_rsTable1 = sprintf("SELECT * FROM tblTable1 WHERE id = %s", GetSQLValueString($Paramid_rsTable1, "int"));
$rsTable1 = mysql_query($query_rsTable1, $dbCMS) or die(mysql_error());
$row_rsTable1 = mysql_fetch_assoc($rsTable1);
$totalRows_rsTable1 = mysql_num_rows($rsTable1);
$colname_rsTable2 = "-1";
if (isset(
$_GET['id'])) {
$colname_rsTable2 = (get_magic_quotes_gpc()) ? $_GET['id'] : addslashes($_GET['id']);
$query_rsTable2 = sprintf("SELECT * FROM tblTable2 WHERE id = %s", GetSQLValueString($colname_rsTable2, "int"));
$rsTable2 = mysql_query($query_rsTable2, $dbCMS) or die(mysql_error());
$row_rsTable2 = mysql_fetch_assoc($rsTable2);
$totalRows_rsTable2 = mysql_num_rows($rsTable2);?>
TroyD
It seems that there may be a problem regarding the value that is referenced for the id. Does your second form have this element in it that holds the id of the record to be updated? It may be easier to debug the page by looking at the code on it. Please post back and include a copy of the page in a zip archive so we can take a look.
troyd
Well, it has the hidden field that echos the id for that recordset, if that's what you are referring to. The form fills in with all the correct information. I even changed the hidden field to a text field just so I could see the id for myself. Plus, the url contains the id for the record just before I click the update button. Then it's gone.
Here's the update page with both forms.
Thanks,
TroyD
It looks like there are two problems here. The first issue is that your second update is using the posted WADAUpdateRecordID value from the first form. This will not work since this values is not present if the second form is used. The name of the element that holds the id in the second form is WADAUpdateRecordID2. You will need to edit your second update to make use of this form element.
The second problem is that the hidden form field that your second form is using for the id is not being set, here is the field from the second form:
html:
<input name="WADAUpdateRecordID2" type="hidden" id="WADAUpdateRecordID2" value="" />
You will need to set the value of this element in the second form to the id from the recordset for the record that is being updated like this:
<input name="WADAUpdateRecordID2" type="hidden" id="WADAUpdateRecordID2" value="<?php echo(rawurlencode($row_rsStickyHH['id'])); ?>" />
troyd
Eric,
Amazing. I can't believe I missed that. I feel like an idiot. And you caught it right away. Thanks so much, it's working perfectly now. I scrubbed through all the update code and form functions and ended up missing a simple field value. Another lesson learned.
Thanks again,
TroyD
You welcome, sometime it just helps to have another set of eyes look at things.
