Problem refreshing <div class="addToCart"> in Products_Detail.php
Thread begun 1/20/2010 3:10 am by davas56386677 | Last modified 2/17/2010 5:33 pm by Dani Chankhour | 7191 views | 14 replies |
davas56386677
Products_Detail.php uses a script to refresh ProductName, ProductPrice in the <div class="addToCart"> when you select either an option or one of its values.
Using ISO-8859-1 character set [Oh yes, I’m the guy using French characters :-)] the initial ProductName is displayed nicely with accented characters as well in Firefox 3.5 (see pic1.jpg) as in IE8 (pic3.jpg).
When selecting another option or value of the product, then the script returns the ProductName as shown in pic2.jpg (Firefox) and pic4.jpg (IE). The red font color (temporarily set within the <h1> tag in Products_Detai.php) is reverted to the green font color I defined in the css for the <h1> tag.
The script appears to first check xmlHttp=new XMLHttpRequest() (for Firefox, Opera 8.0+, Safari) then xmlHttp=new ActiveXObject("Msxml2.XMLHTTP") and finally xmlHttp=new ActiveXObject("Microsoft.XMLHTTP") depending on catch(e).
Could one tell me what to change in that script or elsewhere in the code, to get the French characters displayed correctly in red after selecting either an option or a value of that option and without having to change the default font color of the <h1> tag in the css.
Thank you
Dan
I'm trying to replicate the problem in fresh install of power store, but cannot see the issue. I have added an item to the catalog using french accented characters in the name, and description fields and added different options for that item. Some options are set with 0 inventory, some are not available on line. All of the options correctly show the name. It would seam there is a modification that you have made to the power store files that is causing the problem to occur.
davas56386677
Still sticking with é displayed as &#65533; in Products_Detail.php
Before going on investigating the reason why the é are displayed as a &#65533; in WADAPageTitle after choosing a different OPTION of the product, I'd like to know how your MySQL server at WebAssist is configured:
Connection collation : utf8_general_ci or what else ???
Database charset : UTF-8 Unicode (utf8) or what else ???
Table collation : utf8_general_ci or what else ???
Varchar collation : utf8_general_ci or what else ???
Analyzing the script in Products_Detail.php that updates the WADAPageTitle without refreshing the complete page I noticed that the content is fetched by document.getElementById("WADAPageTitle").innerHTML = getFromRSDump(theRet,"ProductName");
I tried a new product with a lot of é in the ProductName and different options, but the problem persists.
So before going on with my tests I want to be sure if the problem finally relies on the MySQL server configuration.
P.S. I changed all <meta http-equiv="Content-Type" content="text/html; charset=UTF-8 "/> to ISO-8859-1. Doing this solved apparently the problems I had with the Dynamic Web Charts in POWERSTORE 2. Now french characters display accordingly in the charts.
Thank you for telling me the configuration of WebAssist's MySQL server.
Regards
Dan
these are the settings my connection is using:
Server Character Set: latin1
Client Character Set: utf-8
Database Character Set: latin1
Table Engine: innoDB
Table Collation: latin1_Swedish_ci
Varchar collation: latin1_Swedish_ci
Connection collation: latin1_Swedish_ci
davas56386677
Thank you Jason
I'll gonna do the testing tomorrow with the settings provided in your post and revert to you to report the results.
Regards
Dan
davas56386677
Converting DOT into COMMA in "thePriceField" (script) in Products_Detail.php
Hi Jason
I made a fresh install of Powerstore 2 on my PC and configure the MySQL server according to your settings.
The ProductName is now displaying the french accented characters the right way when selecting an option or a value.
I modified somewhat the script of the function updateProduct(ProdID) in Products_Detail.php to display the EUROI currency symbol after the price:
var theForm = document.getElementById("WA_Store_Cart_1_ATC_<?php echo $row_WADAProducts["ProductID"]; ?>");
xmlHttp.onreadystatechange=function()
if(xmlHttp.readyState==4)
if (xmlHttp.responseText != "") {
var theRet=xmlHttp.responseText;
var thePriceField = getFromRSDump(theRet,"ProductPrice");
if (thePriceField.indexOf(".")==-1) {
thePriceField += ",00 €";
if (thePriceField.indexOf(".")==thePriceField.length-2) {
thePriceField += "0 €";
document.getElementById("ProductPrice").innerHTML = thePriceField;
Can you help me to get rid of the "dot" as a decimal character in this script, because we use a "comma" to separate decimals ?
I think of converting the DOT into a COMMA within "thePriceField", but don't know how to do it !
Thank you for your kind help
Dan
the code I have is:
var thePriceField = "$"+ getFromRSDump(theRet,"ProductPrice");
thePriceField += ".00";
thePriceField += "0";
is was able to get it to use the comma by changing that to:
var thePriceField = "€"+ getFromRSDump(theRet,"ProductPrice");
thePriceField += ",00";
davas56386677
Here my solution and additional question
Hi Jason,
In order to display the price in EUR (right side) in Products_Detail.php when selecting either options or values, I had to add a function handling separators in "thePriceField" within the script. Look below (the whole script with modified code for "thePriceField" and added function "addSeparatorsNF(nStr, inD, outD, sep)":
<script>
function updateProduct(ProdID) {
var xmlHttp;
try
// Firefox, Opera 8.0+, Safari
xmlHttp=new XMLHttpRequest();
catch (e)
// Internet Explorer
try
xmlHttp=new ActiveXObject("Msxml2.XMLHTTP");
catch (e)
try
xmlHttp=new ActiveXObject("Microsoft.XMLHTTP");
catch (e)
return false;
thePriceField = addSeparatorsNF(thePriceField, '.', ',', '.');
thePriceField = thePriceField += " €";
document.getElementById("ProductCartDesc").innerHTML = getFromRSDump(theRet,"ProductName");
document.getElementById("ProductLongDesc").innerHTML = getFromRSDump(theRet,"ProductLongDesc");
//document.getElementById("ProductShortDesc").innerHTML = getFromRSDump(theRet,"ProductShortDesc");
document.getElementById("ProductImage").src = "Images/Upload/" + getFromRSDump(theRet,"ProductImage");
document.getElementById("WA_Store_Cart_1_ID_Add").value = getFromRSDump(theRet,"ProductID");
theForm.action = theForm.action.replace(/ProductID=\d*/,"ProductID="+getFromRSDump(theRet,"ProductID"));
document.getElementById("checkingAvail").style.display="none";
if ((parseFloat(getFromRSDump(theRet,"NumLeft")) > 0 || parseInt(getFromRSDump(theRet,"ProductUnlimited")) != 0) && parseInt(getFromRSDump(theRet,"ProductLive")) != 0) {
document.getElementById("addFields").style.display="block";
if (parseInt(getFromRSDump(theRet,"ProductLive")) == 0) {
document.getElementById("notSold").style.display="block";
if (parseFloat(getFromRSDump(theRet,"NumLeft")) <= 0 && parseInt(getFromRSDump(theRet,"ProductLive")) != 0 && parseInt(getFromRSDump(theRet,"ProductUnlimited")) == 0) {
document.getElementById("soldOut").style.display="block";
var numOptions = 0;
numOptions = theRet.match(/\['options'\]=>([^\r\n]*)/);
if (parseInt(numOptions[1]) > 0) {
updateOptions(theRet.substring(theRet.indexOf(numOptions[0])+numOptions[0].length));
for (var x=0; x<theForm.elements.length; x++) {
theForm.elements.item([x]).removeAttribute("disabled");
var thepage = "Products_Detail_Lookup.php?ProductID="+ProdID;
xmlHttp.open("GET",thepage,true);
xmlHttp.send(null);
document.getElementById("addFields").style.display="none";
document.getElementById("notSold").style.display="none";
document.getElementById("soldOut").style.display="none";
document.getElementById("checkingAvail").style.display="block";
theForm.elements.item([x]).disabled="disabled";
function updateOptions(theOptions) {
var theNameMatch = theOptions.match(/\['name'\]=>([^\r\n]*)/);
while (theNameMatch) {
theOptions = theOptions.substring(theOptions.indexOf(theNameMatch[0]) + theNameMatch[0].length);
nextName = theOptions.match(/\['name'\]=>([^\r\n]*)/);
nextIndex = theOptions.length;
if (nextName) {
nextIndex = theOptions.indexOf(nextName[0]);
nextValue = theOptions.match(/\['value'\]=>([^\r\n]*)/);
x = 0;
while (nextValue && theOptions.indexOf(nextValue[0]) < nextIndex) {
document.getElementById(theNameMatch[1].replace(/[\n\r\t]/g,"")).options[x].value = nextValue[1];
nextIndex-=theOptions.indexOf(nextValue[0]) + nextValue[0].length;
theOptions = theOptions.substring(theOptions.indexOf(nextValue[0]) + nextValue[0].length);
x++;
function getFromRSDump(RSDump,colName) {
var theReg = new RegExp('\\s\\["'+colName+'"\\]=>\\s([\\w\\W]*)');
var theMatch = RSDump.match(theReg);
var theRet = "";
if (theMatch) {
var nextMatch = theMatch[1].search(/\s\["[^\r\n]*"\]=>/);
if (nextMatch > 0) {
theMatch[1] = theMatch[1].substring(0,nextMatch);
theRet = theMatch[1].substring(theMatch[1].indexOf('"')+1,theMatch[1].lastIndexOf('"'));
return theRet;
function addSeparatorsNF(nStr, inD, outD, sep)
nStr += '';
var dpos = nStr.indexOf(inD);
var nStrEnd = '';
if (dpos != -1) {
nStrEnd = outD + nStr.substring(dpos + 1, nStr.length);
nStr = nStr.substring(0, dpos);
var rgx = /(\d+)(\d{3})/;
while (rgx.test(nStr)) {
nStr = nStr.replace(rgx, '$1' + sep + '$2');
return nStr + nStrEnd;
</script>
This modified script within Products_Detail.php may be of interest to everybody who needs to display the price like "12.345,67 €". Those who need another currency symbol have just to modify the line "thePriceField = thePriceField += " €"; replacing the € symbol with whatever needed.
Just a little question: in DYNAMICWEBCHART used in Powerstore 2 for instance in Products_Chart_Results_Data1.php the french accented characters contained in ProductName (or similar) to fill #key# in <![CDATA[Pour: #x_label#<br>#key#<br>Unit%c3%a9(s) vendue(s): #val# ]]> are displayed as an é instead of an é. This happened since I made the fresh install of Powerstore using your MySQL configuration.
Remember: I changed all charset=ISO-8859-1 to charset=UTF-8 to comply the closest possible to the original Powerstore 2 (out of the box). The only charsets left to ISO-8859-1 are those within the PHP files that handle the data for the charts (in the \data subdirectory). When changing these particular chasets to UTF-8, the chart stops building up and displays only vertical lines (the tooltip shows: undefined).
<point datagroup="Total">
<label><?php echo($start); ?></label>
<value><?php echo($total); ?></value>
<tooltip>
</tooltip>
<pointlink>Products_Chart_Daily.php?month=<?php echo($month); ?>%26year=<?php echo($year); ?>%26ProductSKU=<?php echo($sku); ?></pointlink>
</point>
Keep in mind that when using charset=ISO-8859-1 throughout the complete Powerstore 2 package and MySQL configured with utf8_general_ci (or utf8_unicode_ci) then the é are stored as é within the database field and displays also correctly (as é) in the chart, thus avoidind the troubles encountered now.
So to me it seems that there must be a trick (encoding - decoding feature) to foul the chart builder so that he translates the é (actual configuration of the fresh install as told by you in previous post) into é. A similar problem occurs in the receipt.php (WA_Universal_Email\Email_Templates), where the
<?php echo $WA_Store_Cart->DisplayInfo("Name"); ?> displays as Société instead of Société within the confirmation email the customer receives.
Ask the team to check this in depth and help me to find where in the complete Powerstore 2 code a explicit encoding - decoding is used to configure the output (email and chart side)
Many thanks for your assistance
Dan
davas56386677
Here 3 slides to document the problem with Dynamic WebCharts in Powerstore 2
Please read the red legends in the slides
Maybe your team shall now understand my concerns related to foreign characters in DWC and in receipt.php of Universal Email in Powerstore 2
davas56386677
LARGER PICTURES in JPG format
Sorry but I noticed that PNGs are to small to read effectively, so please find hereinafter JPGs
